hi,
i used  armbian 5.14 (3.4.112)and the gc2035 worked nice.
but in armbain 5.30  (3.4.113)the gc2035  shows the error : [CSI_ERR][GC2035]sensor_read err at sensor_detect!
        [CSI_ERR][GC2035]chip found is not an target chip.
and in h3droid ,one of android img fo opi ,it was built in 3.4.113 too ,and it failed again...
so what can i do to use gc2035 under .img built with  3.4.113?
thanks.
solved 。
sunxi-pio -m "PG11<1><0><1><1>"
to set PG11 enabled.
now work on h3droid .
it should be the same on armbian 5.30.
perhaps a dump question, but I try the same...
where did you put
on h3droid to get it working?
He made it working under android... on linux I would know. But on h3droid I can't find init scripts, I'm no android expert I'm afraid.
