Lele Posted January 4, 2025 Posted January 4, 2025 I want to install jellyfin on my OrangePi 5 Plus and need OpenCL to enable HDR-SDR mapping. I tried to follow the instruction on Jellyfin's official website: Rockchip VPU | Jellyfin However, I'm stucked on the step of installing OpenCL. I also tried this: Install OpenCL on Debian and Ubuntu and Armbian for Orange Pi 5 RK3588 But no luck either. Both instruction led to broken hardware acceleration in chrome and failing to start kernal in Jellyfin. Logs from ffmpeg: sudo /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab055f5460] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaab055f5460] 1 OpenCL devices found on platform "ARM Platform". arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab055f5460] 0.0: ARM Platform / Unknown Device Segmentation fault Logs from Jellyfin: Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Logs from clinfo: arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded I want to know how to correctly enable OpenCL on OrangePi 5 Plus, thank you! 0 Quote
going Posted January 4, 2025 Posted January 4, 2025 34 минуты назад, Lele сказал: I want to know how to correctly enable OpenCL on OrangePi 5 Plus, thank you! Please let the community know which core your device is running on. 0 Quote
Lele Posted January 5, 2025 Author Posted January 5, 2025 Quote Please let the community know which core your device is running on. Maybe it's this? > uname -r 6.1.75-vendor-rk35xx I'm using this img: Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img After installed, I used armbian-config to disable the firmware update (because otherwise apt upgrade also break hardware acceleration in chrome). Then I ran: sudo apt update sudo apt upgrade Then, following jellyfin's guide (Rockchip VPU | Jellyfin), in /etc/udev/rules.d/99-rk-device-permissions.rules, I also changed this: KERNEL=="system", MODE="0660", GROUP="video" to this: KERNEL=="system", MODE="0666", GROUP="video" I also paste the whole clinfo message here: pastebin (clinfo) 0 Quote
ozacas Posted May 11, 2025 Posted May 11, 2025 At a guess, you are probably running the panthor gpu driver rather than the mali kernel driver. To check this, run something like: sudo dmesg | grep -i panthor and report what comes back. Further information can be found at https://forum.jellyfin.org/t-rockchip-transcode-missing-dev-mali0 Hope this helps, 0 Quote
