I have an orange pi+ 2e that is being used for pihole. I want to set my pi to use 1 cpu core, disable usb ports and set Ethernet link speed at 100Mb/s etc to reduce consumption however not all the changes will apply at once (see picture attached) If cpu is running at one core and ram at reduced speed, ethernet link speed will still be at 1gbps and the other way round when Link speed is at 100Mbps.
Something similar happens to me with an Orange Pi Lite.
Not all changes are made and it seems as if some are reversing others (for example DRAM speed and number of active cores).
Basic h3consumption mode of operation:
  • adjust settings
  • reboot
  • check settings
  • if something seems to be strange provide output of 'armbianmonitor -u' and TEXTUAL output from 'h3consumption -p' (no screenshots!)
There was an issue with CPU cores not being brought up back but this should be fixed in the meantime (though no idea whether this is already part of latest board support package and of course whether users install available updates or not)
In my case the problem occurs when I try to change DRAM speed and the number of active cores as though they were incompatible with each other.
I attach the output of the terminal and /var/log/armhwinfo.log.
alejandro@orangepilite:~$ sudo h3consumption -p
[sudo] password for alejandro:
Active settings:
cpu       912 mhz allowed, 1200 mhz possible, 4 cores active
dram      408 mhz
hdmi/gpu  off
usb ports off
wlan0     IEEE 802.11bgn  ESSID:"Flybox"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.412 GHz  Access Point: D4:6E:0E:68:95:A9
          Bit Rate:150 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=90/100  Signal level=75/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
alejandro@orangepilite:~$ sudo h3consumption -c 1
Settings changed. Please reboot for changes to take effect
and verify settings after the reboot using "h3consumption -p"
alejandro@orangepilite:~$ sudo shutdown -r now
Connection to 192.168.50.24 closed by remote host.
Connection to 192.168.50.24 closed.
alejandro@GP60-2PE:~$ ssh alejandro@192.168.50.24
alejandro@192.168.50.24's password:
  ___                               ____  _   _     _ _
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) | |   (_) |_ ___
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |   | | __/ _ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| | | |___| | ||  __/
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_____|_|\__\___|
                       |___/
Welcome to ARMBIAN 5.31 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i
System load:   0.12 0.18 0.12      Up time:       6 min
Memory usage:  7 % of 494MB      IP:            192.168.50.24
CPU temp:      51°C
Usage of /:    9% of 15G
Last login: Sun Aug 13 16:09:52 2017 from 192.168.50.19
Active settings:
cpu       912 mhz allowed, 1200 mhz possible, 1 cores active
dram      624 mhz
hdmi/gpu  off
usb ports off
          Link Quality=86/100  Signal level=76/100  Noise level=0/100
alejandro@orangepilite:~$ uname -a
Linux orangepilite 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l armv7l armv7l GNU/Linux
alejandro@orangepilite:~$ sudo armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/RaUT
Please post the URL in the Armbian forum where you've been asked for.
I looked into this today but can't reproduce. All the script is doing wrt those two options is putting some lines of code to /etc/rc.local to be executed on next reboot.
Please play around with h3consumption and watch after each change contents of /etc/rc.local. If you're not updated to latest versions please do this first. And if you find a way to reproduce please share.
Installation is recent and updated. I really haven't yet started playing with it, so I can't say something special to be able to reproduce this.
Apparently whenever I use h3consumption with any of its options the previous content of /etc/rc.local is removed, so the last actions are reset to their default value.
For instance, when I use sudo h3consumption -c 1 (and after restart).
alejandro@orangepilite:~$ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
### do NOT edit the following lines, always use h3consumption instead ###
for i in 3 2 1; do echo 0 >/sys/devices/system/cpu/cpu${i}/online; done # h3consumption
exit 0
Then I apply sudo h3consumption - d 408, reboot, and the new content is:
#!/bin/sh -e
# rc.local
# value on error.
# bits.
echo 408000 >/sys/devices/platform/sunxi-ddrfreq/devfreq/sunxi-ddrfreq/userspace/set_freq # h3consumption
exit 0
Can you please compare contents of script on disk and latest revision on Github?
curl -s 'https://raw.githubusercontent.com/armbian/build/master/packages/bsp/h3consumption' | md5sum
md5sum /usr/bin/h3consumption
If MD5 hashes don't match please update h3consumption manually, try again and report back.
sudo -s
curl -s 'https://raw.githubusercontent.com/armbian/build/master/packages/bsp/h3consumption' >/usr/bin/h3consumption
I was wrong, thank you for telling me how to check it :)
Now MD5 hashes match (2f0fb2eeed6055a12dd8f5cdaed2fdc2 it's the value). Unfortunately the problem remains unresolved.
I have tried editing '/etc/rc.local' by myself and I've managed to run with the desired configuration.
As the problem seems like it can't be reproduced, it may be something very particular of my environment. Probably with a fresh reinstallation it would be solved.
So, unless others report the same problem, I suggest not continuing with this issue.
Thanks!
