Dome Posted January 11, 2025 Posted January 11, 2025 I installed armbian with a vendor kernel 6.1.75-vendor-rk35xx. I want to be sure the kernel is not updated. I used armbian-config and selected "SY203 - Disable Armbian kernel upgrades" Disable Armbian kernel/firmware upgrades Would you like to continue? after selecting "Yes", the menu shows "SY202 - Enable Armbian firmware upgrades" so I check with apt-mark showhold and it returned only "armbian-firmware" Do I have to put my kernel packages on hold? linux-dtb-vendor-rk35xx linux-headers-vendor-rk35xx linux-image-vendor-rk35xx I find misleading the change in the description from SY203 to SY202: kernel -> firmware 0 Quote
Solution Werner Posted January 11, 2025 Solution Posted January 11, 2025 This seems like a bug to me. The linux-*-vendor packages you mentioned should be frozen with this option as well. I forwarded this to the repo: https://github.com/armbian/configng/issues/368 0 Quote
