rcr Posted January 19, 2025 Posted January 19, 2025 Hello! After installing Debian stable (bookworm) v25.2 on my Cubietruck from SD card to SSD using armbian-install and then moving boot to SSD using armbian-config: Install/Update the bootloader on (/dev/sda/) i'm trying to boot with SD card removed and ending up in this strange android GUI. My /etc/fstab is looking like this: # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=723a49f7-ffc6-4d66-8198-07d4ac71688f /media/mmcboot ext4 defaults,noatime,commit=120,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=7e00bf90-f9ea-4755-95f7-96d37a2d9642 / ext4 defaults,noatime,commit=120,errors=remount-ro,x-gvfs-hide 0 1 I would like to boot from internal SSD without having SD card inserted. What am I missing? 0 Quote
Solution Igor Posted January 19, 2025 Solution Posted January 19, 2025 1 hour ago, rcr said: What am I missing? Reading the A20 SoC documentation? tl;dr; That is not possible on this hardware as boot from NAND is not supported on modern U-boot / Linux. 0 Quote
rcr Posted January 19, 2025 Author Posted January 19, 2025 (edited) Thank you for quick reply. Haven't even thought it's not supported. PS: I wanted to thank the developers for such build / config tool! It worked like a charm as I decided to upgrade from Ubuntu xenial. Edited January 19, 2025 by rcr 1 Quote
pet Posted January 25, 2025 Posted January 25, 2025 I would like to ask what is the reason to NOT support to boot from NAND on cubietruck. Several years ago it worked out ok. I/O speed is not important for me, but i remember some armbian developers commented it is not supported anymore because it is too slow. I do not use my cb3 for speed, but for stableness. When booting from NAND is not supported on modern u-boot/linux, why does it work on my NanoPI Neo Plus2? 0 Quote
