Tiedemate Posted January 21, 2025 Posted January 21, 2025 Hi! I just flashed Armbian 24.11.1 Bookworm Minimal / IOT onto my Odroid HC1 SD-Card. The download page states: "For HC1 and HC2 we provide specially optimized config which has to be applied manually. This results in shorter boot time and lower consumption. Edit /boot/armbianEnv.txt and add: board_name=xu4 # or xu3, xu3, hc1" However there is no /boot/armbianEnv.txt. Should I just run the system as is or do I have to modify something to have it run optimally? Should I just create the file and add line? Thx! Björn 0 Quote
Igor Posted January 22, 2025 Posted January 22, 2025 If there is a bug: https://github.com/armbian/configng/pull/298 then there must be a feature Perhaps there is still /boot/boot.ini ?... search in there. 0 Quote
Tiedemate Posted January 22, 2025 Author Posted January 22, 2025 Hi Igor, thanks for your reply! There is a boot.ini, and it states: # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # So now I just created /boot/armbianEnv.txt and added board_name=hc1 to it. I hope it's that easy? Thanks again! Björn 0 Quote
Tiedemate Posted January 22, 2025 Author Posted January 22, 2025 Hm, that seems not to have worked, I still get: v24.11.1 for Odroid XU4 running Armbian Linux 6.6.60-current-odroidxu4. 0 Quote
Igor Posted January 24, 2025 Posted January 24, 2025 On 1/22/2025 at 10:22 AM, Tiedemate said: There is a boot.ini, and it states: Search for board_name variable in boot.ini and try to change that. 0 Quote
