Mentaluproar Posted January 28, 2025 Posted January 28, 2025 (edited) I'm trying to install Jellyfin in a docker container to get hardware acceleration, I need to pass /dev/mali0 to the container. I'm running the 6.1.84-vendor-rk35xx kernel. Below are my clinfo results What am I forgetting here? Quote sean@spitemachine:~$ clinfo arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Number of platforms 1 Platform Name ARM Platform Platform Vendor ARM Platform Version OpenCL 3.0 v1.g13p0-01eac0.9113fb3d6cbac82527a272992153edf9 Platform Profile FULL_PROFILE Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp16 cl_khr_icd cl_khr_egl_image cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_subgroups cl_khr_subgroup_extended_types cl_khr_subgroup_non_uniform_vote cl_khr_subgroup_ballot cl_khr_subgroup_non_uniform_arithmetic cl_khr_subgroup_shuffle cl_khr_subgroup_shuffle_relative cl_khr_subgroup_clustered_reduce cl_khr_subgroup_rotate cl_khr_il_program cl_khr_priority_hints cl_khr_create_command_queue cl_khr_spirv_no_integer_wrap_decoration cl_khr_extended_versioning cl_khr_device_uuid cl_khr_suggested_local_work_size cl_khr_extended_bit_ops cl_khr_integer_dot_product cl_khr_semaphore cl_khr_external_semaphore cl_khr_external_semaphore_sync_fd cl_khr_command_buffer cl_arm_core_id cl_arm_printf cl_arm_non_uniform_work_group_size cl_arm_import_memory cl_arm_import_memory_dma_buf cl_arm_import_memory_host cl_arm_integer_dot_product_int8 cl_arm_integer_dot_product_accumulate_int8 cl_arm_integer_dot_product_accumulate_saturate_int8 cl_arm_scheduling_controls cl_arm_controlled_kernel_termination cl_ext_cxx_for_opencl cl_ext_image_tiling_control cl_ext_image_requirements_info cl_ext_image_from_buffer Platform Extensions with Version cl_khr_global_int32_base_atomics 0x400000 (1.0.0) cl_khr_global_int32_extended_atomics 0x400000 (1.0.0) cl_khr_local_int32_base_atomics 0x400000 (1.0.0) cl_khr_local_int32_extended_atomics 0x400000 (1.0.0) cl_khr_byte_addressable_store 0x400000 (1.0.0) cl_khr_3d_image_writes 0x400000 (1.0.0) cl_khr_int64_base_atomics 0x400000 (1.0.0) cl_khr_int64_extended_atomics 0x400000 (1.0.0) cl_khr_fp16 0x400000 (1.0.0) cl_khr_icd 0x400000 (1.0.0) cl_khr_egl_image 0x400000 (1.0.0) cl_khr_image2d_from_buffer 0x400000 (1.0.0) cl_khr_depth_images 0x400000 (1.0.0) cl_khr_subgroups 0x400000 (1.0.0) cl_khr_subgroup_extended_types 0x400000 (1.0.0) cl_khr_subgroup_non_uniform_vote 0x400000 (1.0.0) cl_khr_subgroup_ballot 0x400000 (1.0.0) cl_khr_subgroup_non_uniform_arithmetic 0x400000 (1.0.0) cl_khr_subgroup_shuffle 0x400000 (1.0.0) cl_khr_subgroup_shuffle_relative 0x400000 (1.0.0) cl_khr_subgroup_clustered_reduce 0x400000 (1.0.0) cl_khr_subgroup_rotate 0x400000 (1.0.0) cl_khr_il_program 0x400000 (1.0.0) cl_khr_priority_hints 0x400000 (1.0.0) cl_khr_create_command_queue 0x400000 (1.0.0) cl_khr_spirv_no_integer_wrap_decoration 0x400000 (1.0.0) cl_khr_extended_versioning 0x400000 (1.0.0) cl_khr_device_uuid 0x400000 (1.0.0) cl_khr_suggested_local_work_size 0x400000 (1.0.0) cl_khr_extended_bit_ops 0x400000 (1.0.0) cl_khr_integer_dot_product 0x800000 (2.0.0) cl_khr_semaphore 0x9000 (0.9.0) cl_khr_external_semaphore 0x9000 (0.9.0) cl_khr_external_semaphore_sync_fd 0x9000 (0.9.0) cl_khr_command_buffer 0x9000 (0.9.0) cl_arm_core_id 0x400000 (1.0.0) cl_arm_printf 0x400000 (1.0.0) cl_arm_non_uniform_work_group_size 0x400000 (1.0.0) cl_arm_import_memory 0x400000 (1.0.0) cl_arm_import_memory_dma_buf 0x400000 (1.0.0) cl_arm_import_memory_host 0x400000 (1.0.0) cl_arm_integer_dot_product_int8 0x400000 (1.0.0) cl_arm_integer_dot_product_accumulate_int8 0x400000 (1.0.0) cl_arm_integer_dot_product_accumulate_saturate_int8 0x400000 (1.0.0) cl_arm_scheduling_controls 0x4000 (0.4.0) cl_arm_controlled_kernel_termination 0x400000 (1.0.0) cl_ext_cxx_for_opencl 0x400000 (1.0.0) cl_ext_image_tiling_control 0x1000 (0.1.0) cl_ext_image_requirements_info 0x5000 (0.5.0) cl_ext_image_from_buffer 0x400000 (1.0.0) Platform Numeric Version 0xc00000 (3.0.0) Platform Extensions function suffix ARM Platform Host timer resolution 1ns Platform Semaphore types Binary Platform External semaphore import types 0 Platform External semaphore export types 0 Platform Name ARM Platform Number of devices 1 arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Device Name <printDeviceInfo:0: get CL_DEVICE_NAME size : error -6> Device Vendor ARM arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Device Vendor ID <printDeviceInfo:2: get CL_DEVICE_VENDOR_ID : error -6> Device Version OpenCL 3.0 v1.g13p0-01eac0.9113fb3d6cbac82527a272992153edf9 arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Device UUID <printDeviceInfo:6: get CL_DEVICE_UUID_KHR : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Driver UUID <printDeviceInfo:7: get CL_DRIVER_UUID_KHR : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Valid Device LUID <printDeviceInfo:8: get CL_DEVICE_LUID_VALID_KHR : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Device LUID <printDeviceInfo:9: get CL_DEVICE_LUID_KHR : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Device Node Mask <printDeviceInfo:10: get CL_DEVICE_NODE_MASK_KHR : error -6> Device Numeric Version 0xc00000 (3.0.0) Driver Version 3.0 Device OpenCL C Version OpenCL C 3.0 v1.g13p0-01eac0.9113fb3d6cbac82527a272992153edf9 Device OpenCL C Numeric Version 0xc00000 (3.0.0) Device OpenCL C all versions OpenCL C 0x400000 (1.0.0) OpenCL C 0x401000 (1.1.0) OpenCL C 0x402000 (1.2.0) OpenCL C 0x800000 (2.0.0) OpenCL C 0xc00000 (3.0.0) Device OpenCL C features __opencl_c_images 0x400000 (1.0.0) __opencl_c_int64 0x400000 (1.0.0) __opencl_c_3d_image_writes 0x402000 (1.2.0) __opencl_c_atomic_order_acq_rel 0x800000 (2.0.0) __opencl_c_atomic_order_seq_cst 0x800000 (2.0.0) __opencl_c_atomic_scope_device 0x800000 (2.0.0) __opencl_c_atomic_scope_all_devices 0x800000 (2.0.0) __opencl_c_device_enqueue 0x800000 (2.0.0) __opencl_c_generic_address_space 0x800000 (2.0.0) __opencl_c_pipes 0x800000 (2.0.0) __opencl_c_program_scope_global_variables 0x800000 (2.0.0) __opencl_c_read_write_images 0x800000 (2.0.0) __opencl_c_subgroups 0x800000 (2.0.0) __opencl_c_work_group_collective_functions 0x800000 (2.0.0) Device C++ for OpenCL Numeric Version 0x400000 (1.0.0) Latest conformance test passed v2021-03-05-00 Device Type GPU Device Profile FULL_PROFILE Device Available Yes Compiler Available Yes Linker Available Yes arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Max compute units <printDeviceInfo:32: get CL_DEVICE_MAX_COMPUTE_UNITS : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Available core IDs (ARM) <printDeviceInfo:33: get CL_DEVICE_COMPUTE_UNITS_BITFIELD_ARM : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Max clock frequency <printDeviceInfo:40: get CL_DEVICE_MAX_CLOCK_FREQUENCY : error -6> Device Partition (core) Max number of sub-devices 0 Supported partition types None Supported affinity domains (n/a) Max work item dimensions 3 arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Max work item sizes <printDeviceInfo:62: get number of CL_DEVICE_MAX_WORK_ITEM_SIZES : error -6> arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Max work group size <printDeviceInfo:63: get CL_DEVICE_MAX_WORK_GROUP_SIZE : error -6> Preferred work group size multiple (device) 16 Segmentation fault Edited January 28, 2025 by Mentaluproar 0 Quote
Solution Mentaluproar Posted January 28, 2025 Author Solution Posted January 28, 2025 Found the solution. disable panthor from the dt overlays. 0 Quote
