Hi,
I installed armbian on the emmc of Magicsee N5+, it  work very well. But after kernel update, I'm unable to restart the emmc system ....
I tried 5x on the 3 last month, and I always have the same issue ....
Is there any solution ?
Maybe it links with this error message after update :
Try booting from an SD card, and then try to boot from emmc.  I have one box that won't reboot without first doing a boot from SD.  But after a boot from an SD card, then it will boot from EMMC correctly.
4 hours ago, xNiux said:
I tried a u-boot-refresh from usb system
What do you mean by that.  Please be specific as I don't know what you are referring to.
Hi started a fresh amrbian system from USB, and I hopped the command u-boot-refresh detect emmc system and add it to the boot choice.
Never heard of this command.  What does it do?  What do you mean by add it to the boot choice?
Have you read and followed the instructions on this site to install to emmc?
Yes for sure, and the installation on emmc work perfectly.
I don't know if it's normal, but starting with a USB system, I can't mount any emmc partition ....  So, I can't get my datas, or try to restore emmc boot 😢
Ok, I successfully mounted the /dev/mmblk1p1 partition. And I understand the problem extlinux.conf is incomplete, it missing labels ...
I will try to install a cleanly system on emmc, and trace the problem on next kernel upgrade
OK, previous problem come from the command u-boot-refresh, which erased extlinux.conf.
So, I reinstall properly the system on emmc. And after the upgrade and reboot, I have more detail.... First : I have a black screen, and the only possibility is to put the USB key with armbian and restart the box with the toothstick.
I joined to this message the debug COM log when I have the black screen.
debugUsb.txt
In your log you will see:
Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 1: Armbian 25.5.0-trunk.61 bookworm 6.12.13-current-meson64 Retrieving file: /vmlinuz-6.12.13-current-meson64 Skipping l0 for failure retrieving kernel 2: Armbian 25.5.0-trunk.61 bookworm 6.12.13-current-meson64 (rescue target) Retrieving file: /vmlinuz-6.12.13-current-meson64 Skipping l0r for failure retrieving kernel EXTLINUX FAILED: continuing... 78003 bytes read in 43 ms (1.7 MiB/s) Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110
This means that uboot can't reliably read your media.
