Hi everybody,
Since some time i have a problem with my OrangePi Zero2. Not sure about when it started exactly, but possibly it came with the latest kernel upgrade. Until then the device was working without any problems and absolutely stable.
Unfortunately i have no connection by cable, only with Wifi and possibly it is only the Wifi connection which isn't working anymore?
I found the following entries in /var/log/kern (which are the latest entries until the device restarts):
2025-02-10T19:54:40.037397+01:00 orangepizero2 kernel: [86427.304061] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection sm_state (5), status: (2)!
2025-02-10T19:54:40.037459+01:00 orangepizero2 kernel: [86427.304105] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection KNAECKEBROED failed status code:1!
2025-02-10T19:54:40.365435+01:00 orangepizero2 kernel: [86427.632069] sprdwl:sprdwl_fc_add_share_credit, 536, mode:1 closed, index:0, share it
2025-02-10T19:54:55.573468+01:00 orangepizero2 kernel: [86442.837864] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
is this a common issue with one of the latest updates or kernel?
Here the link to the actual armbianmonitor -u  from this device:
https://paste.next.armbian.com/runuloneco
Best regards,
Chris
possibly the same issue like here?
https://forum.armbian.com/topic/37689-unisoc_wifi-disconnections-on-orangepi-zero-3/#elShareItem_791442255_menu
I have a mesh, could this cause this issue?  But why does it occur now and not in the last years?
 Cell 02 - Address: 34:81:C4:11:14:EA
                    Channel:11
                    Frequency:2.462 GHz (Channel 11)
                    Quality=70/70  Signal level=-32 dBm
                    Encryption key:on
                    ESSID:"KNAECKEBROED"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=000000030cd2d358
                    Extra: Last beacon: 140ms ago
                    IE: Unknown: 000C4B4E4145434B4542524F4544
                    IE: Unknown: 010882848B968C129824
                    IE: Unknown: 03010B
                    IE: Unknown: 050400010000
                    IE: Unknown: 0706444520010D14
                    IE: Unknown: 2A0100
                    IE: Unknown: 3204B048606C
                    IE: Unknown: 0B0505000A0000
                    IE: Unknown: 460573D000000C
                    IE: Unknown: 2D1AEF111BFFFFFF00000000000000000001000000000406E6470D00
                    IE: Unknown: 3D160B0F0600000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A002C01C800140005001900
                    IE: Unknown: 7F0805000F0000000040
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: DD0900037F01010000FF7F
                    IE: Unknown: DD088CFDF00101020100
                    IE: Unknown: DD168CFDF004000049000003020972018C160000CDAB0000
                    IE: Unknown: DD0C00040E010102010000000000
                    IE: Unknown: DD1D0050F204104A0001101044000102103C0001011049000600372A000120
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: DD1F8CFDF00000010100000101000000000000FFFF0000000000003481C41114EA
          Cell 03 - Address: 5C:49:79:83:C0:F6
                    Channel:11
                    Quality=67/70  Signal level=-43 dBm
                    Encryption key:on
                    Mode:Master
                    Extra:tsf=000000030cbcca49
                    Extra: Last beacon: 1584ms ago
                    IE: Unknown: 03010B
                    IE: Unknown: 2A0100
                    IE: Unknown: 0B0502000E0000
                    IE: Unknown: DD6F0050F204104A0001101044000102103B00010310470010946CD798D7A5C92D4B7B5C497983C0F61021000341564D1023000446426F78102400043030303010420004303030301054000800060050F20400011011000446426F78100800022388103C0001011049000600372A000120
                        Group Cipher : CCMP
Edited by chaoschris
I pinned the wifi connection now to one specific mac address and give it a try......
root@orangepizero2:/# nmcli dev wifi list
IN-USE  BSSID                       SSID                        MODE   CHAN  RATE             SIGNAL  BARS      SECURITY
*            34:81:C4:11:14:EA  KNAECKEBROED  Infra       11        405 Mbit/s  100          ▂▄▆█  WPA2
              5C:49:79:83:C0:F6  KNAECKEBROED  Infra        11       405 Mbit/s  95            ▂▄▆█  WPA2
              C4:3A:35:B3:B7:5E  Hi-A095344          Infra        3          65 Mbit/s    69            ▂▄▆_   --
              C8:0E:14:01:96:C7  Puff5                      Infra        52        405 Mbit/s  42            ▂▄__   WPA2
You should be able to set the mac address manualy. Make sure you have the one you need written down or emailed to yourself. I would use sudo armbian-config and check all your networking setting and see what your options are for setting the mac.
Also check for files in this directory: /etc/NetworkManager/system-connections/
I doubt problems has anything to do with networking stack. Its more down to the driver quality itself, perhaps (less possible) some changes in wireless section of kernel. This is 2nd worse wireless chip found on single board computers. The winner of worse is (in)famous Xradio, found on Orangepi Zero 1 and few others, for which we lost thousands of hours only to keep it barely functional. Opi tend to use the cheapest WiFi chips they can find ... Quality will probably always remain as is and keeping it build-able with modern kernels will always remain a challenge. This is the same with all wireless stuff. There is a nice project dedicated to Linux WiFi https://github.com/morrownr/USB-WiFi where one can get some overview on the topic.
