Nico059 Posted February 12, 2025 Posted February 12, 2025 (edited) Dear all, sorry if it's a stupid question 😉 ... I successfully install armbian on my SBC (in fact a TV box) for amlogic https://www.armbian.com/amlogic-s9xx-tv-box/ I install this one: Armbian_community_25.5.0-trunk.4_Aml-s9xx-box_bookworm_current_6.12.12.img.xz I use armbian-config / section "software" to add some 3rd party software, and it works very well The choice in the "software" section is limited on my setup, and when I look at the source code (main branch) here https://github.com/armbian/configng/tree/main/tools/modules/software I see more software available.... Is it possible to upgrade only "armbian-config" to have an easy access to all the latest software available ? Or perhaps, just copy/paste the module_xxxxxx.sh that I see on the source code somewhere ? Thanks in advance Folks ! Regards Nico. Edited February 12, 2025 by Nico059 0 Quote
Solution Igor Posted February 13, 2025 Solution Posted February 13, 2025 On 2/12/2025 at 2:10 PM, Nico059 said: Is it possible to upgrade only "armbian-config" to have an easy access to all the latest software available ? Yes, of course. Running apt update + apt upgrade should update armbian-config to the latest. If you want to keep installed software updated, see options in "Updates". You can enable automatic updating of container images. If you are somehow missing sources lists, manual way: https://github.com/armbian/configng/tree/main?tab=readme-ov-file#getting-started 0 Quote
Nico059 Posted February 13, 2025 Author Posted February 13, 2025 Thanks for your quick answer @Igor So this is the standard way to update any package, So easy, I should have test that before posting here .... I just successfully do : apt update apt list --upgradable armbian-config/inconnu 25.5.0-trunk.53.0213.103604 all [pouvant être mis à jour depuis : 25.5.0-trunk.18.0207.210415] --> YES there is an update available apt install armbian-config --> juste to update only this package, to no impact other part of my system And ....TADA ! I now have all the latest "software" available in armbian-config available 😉 thx again 1 Quote
Igor Posted February 13, 2025 Posted February 13, 2025 38 minutes ago, Nico059 said: I now have all the latest "software" available in armbian-config available Nice! In case you will get an idea to add something to this system, this is how it goes: https://docs.armbian.com/Contribute/Armbian-config/ 0 Quote
