Tinerfe Posted February 19, 2025 Posted February 19, 2025 Good evening! Thats my first post, I have for a year a Orangepi 3 LTS that I used for my kid, he looks that never switch off the unit by software and use the switch all the time, so suddenly the unit dont boot anymore, the SD card partition table was corrupt, so I mounted a new OS in another SD but does not boot, the green light is not coming anymore. So I connected a TTL to USB Serial device for debugging and it shows the following information: U-Boot SPL 2021,10-orangepi (Sep 06 2022 - 18:22:23 +0800) PMU: AXP806 DRAM: 2048 MiB Trying to boot from MMC2 NOTICE: NOTICE NOTICE NOTICE: INFOS NOTICE NOTICE: INFO: INFO: INFO? BL31: BL31: BL31: BL31: v2,2( debug) +a04808c1 Built ¢ 19340326, Jul 13 2022 Detected Allwinner H6 SoC (1728) Found U-Boot DTB at OxcO?ea28, model; OrangePi 3 LTS ARM GICv2 driver initialized PMIC; PMIC: BL31: BL31: BL31: Probing AXP805 AXP805 detected Platform setup done Initializing runtime services cortex_a53; CPU workaround for 855873 was applied Unhandled Exception in EL3, x30 = 0x0000000000107410 x0 = 0x0000000000000002 xd = 0x000000000010F550 x2 = 0x0000000000L0F 000 x3 = 0x0000000000000003 x4 = 0x0000000000110840 x5 = 0x000000000010¢320 x6 = 0x0000000000000001 x? = 0x0000000000000001 x8 = 0x0000000000000000 x9 = 0x000000000000000b x10 = 0x0000000000107190 x11 = 0x000000000000000a x12 = 0x0000000000000002 x13 = 0x00000000016e3600 x14 = 0x1261257500c00008 x15 = 0x01108c0150000508 x16 = 0x00000000000268a8 xl? = 0x00000000001093e4 x18 = 0x0000000000000004 x19 = 0x0000000000110000 x20 = 0x000000000010¢430 x21 = 0x0000000000110860 x22 = 0x0000000000000000 x23 = 0x0000000000000001 x24 = OxOO0OO0O0FFFFFFFF x25 = 0x0000000000000004 x26 = 0x0000000000000004 x2? = 0x0000000000110800 x28 = 0x0000000000000001 x29 = 0x000000000010e4b0 ser_el3 = 0x0000000000000238 sctlr_el3 = 0x0000000030cd183F cptr_el3 = 0x0000000000000000 ter_el3 = 0x0000000080803524 daif = 0x00000000000003c0 mair_el3 = OxO0000000004404FF spsr_el3 = 0x00000000600002cc elr_el3 = 0x000000000010637c ttbro_el3 = 0x0000000000110000 esr_el3 = 0x0000000002000000 far_el3 = 0xe0016ce004006210 spsr_el1 = 0x00000000000001ed elr_elt = 0x4b46367831080083 spsr_abt = 0x000000002a0e5034 spsr_und = 0x0000000004144808 spsr_irg = 0x000000006413060c spsr_fig = 0x000000004215329c sctlr_ell = 0x0000000000c50838 actlr_ell = 0x0000000000000000 cpacr_ell = 0x0000000000000000 esselr_elt = 0x0000000000000000 spell = Oxd53c5800200a0030 esr_elt = 0x000000000160028a ttbro_el1 = 0x180122092468¢203 ttbri_ell = 0x82060b6a44506803 mair_ell = 0x44e048e000098aa4 amair_ell = 0x0000000000000000 ter_elt = 0x0000000000000000 tpidr_ell = 0x0077342201851b64 tpidr_eld = 0x0108cec921e9101de tpidrro_eld = Ox226cc058ae6c0166 par_elt = Ox1b0000F40a066390 mpidr_el1 = 0x0000000080000000 afsr0_ell = 0x0000000000000000 afsri_ell = 0x0000000000000000 contextidr_ell = 0x0000000000000000 vbar_el1 = 0x0000000000000000 cntp_ctl_el0 — = 0x0000000000000002 entp_cval_elO = Ox0b30e1c1057e4981 entvictl_el0 — = 0x0000000000000002 entv_cval_el0 = 0x90cBa5a085b6b490 entketl_ell = 0x0000000000000000 sp_el0 = 0x000000000010e4b0 isr_el1 = 0x0000000000000000 dacr32_e12 = 0x0000000008e41ce9 ifsr32_el2 = 0x0000000000000400 cpuectlr_el1 == 0x0000000000000040 cpumerrsr_ell = 0x0000000000000000 l2merrsr_ell — = 0x0000000000000000 cpuactlr_el1 == 0x00001000090ca000 gicc_hppir = OxO0000000000003FF gicc_ahppir = OxO000OOHOOOOOOSFF gicc_ctlr = 0x00000000000001e9 gicd_ispendr regs (Offsets 0x200-0x278) Offset Value 0x2003 0x0090000000000000 0x2083 0x0090000000000000 0x2103 0x0090000000000000 0x2183 0x0090000000000000 0x2203 0x0090000000000000 0x2283 0x0090000000000000 0x2303 0x0090000000000000 0x2383 0x0090000000000000 0x2403 0x0090000000000000 0x2483 0x0090000000000000 0x2503 0x0090000000000000 0x2583 0x0090000000000000 0x2603 0x0090000000000000 0x2683 0x0090000000000000 Ox2703 0x0090000000000000 Ox2783 0x0000000000000000 I guess I need to flash or upload the firmware onto the H6 chip? 0 Quote
Werner Posted February 20, 2025 Posted February 20, 2025 17 hours ago, Tinerfe said: 2021,10-orangepi That seems like sw from vendor. 17 hours ago, Tinerfe said: flash or upload the firmware eMMC onboard memory needs to be erased. Check docs, I don't know by heart how to do it. Maybe there is some pin that can be shorted to ground to disable it. Or there is some tools or flash mode to erase/skip it. Once eMMC is nuked booting from microsd should work just fine. 0 Quote
