numerik Posted February 22, 2025 Posted February 22, 2025 hello, i try to update my armbian and i got this E: Release file for http://security.debian.org/dists/bookworm-security/InRelease is not valid yet (invalid for another 2d 3h 4min 26s). Updates for this repository will not be applied. E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InRelease is not valid yet (invalid for another 2d 2h 59min 29s). Updates for this repository will not be applied. E: Release file for http://deb.debian.org/debian/dists/bookworm-backports/InRelease is not valid yet (invalid for another 2d 2h 59min 29s). Updates for this repository will not be applied. E: Release file for http://apt.armbian.com/dists/bookworm/InRelease is not valid yet (invalid for another 1d 17h 24min 28s). Updates for this repository will not be applied. Error: Package linux-image-vendor-rk35xx install not possible due to network / repository problem. Try again later and report to Armbian forums 0 Quote
Werner Posted February 22, 2025 Posted February 22, 2025 Make sure your time is properly set. 0 Quote
numerik Posted February 22, 2025 Author Posted February 22, 2025 (edited) nothing works, i change my time zone to montreal or new-york, the time is stuck to 4:47pm and is 00:34am... 😕 Edited February 22, 2025 by numerik 0 Quote
Werner Posted February 22, 2025 Posted February 22, 2025 If the time offset is too large things like ntpdate might not work. Try setting manually. Also check date. Most sbcs don't have something like an RTC module or a battery to keep date. 0 Quote
numerik Posted February 22, 2025 Author Posted February 22, 2025 ok, but am new on armbian, how a set manually? 0 Quote
Werner Posted February 22, 2025 Posted February 22, 2025 Since this is userspace any Debian or Ubuntu manual how to do that should work: https://www.google.com/search?q=debian+set+time+and+date 0 Quote
numerik Posted February 22, 2025 Author Posted February 22, 2025 i try the two first tutorial, this is i got after a timedatectl Local time: Sat 2025-02-22 01:35:44 EST Universal time: Sat 2025-02-22 06:35:44 UTC RTC time: Wed 2025-02-19 22:52:34 Time zone: America/New_York (EST, -0500) System clock synchronized: no NTP service: active RTC in local TZ: no 0 Quote
Werner Posted February 22, 2025 Posted February 22, 2025 40 minutes ago, numerik said: Universal time: Sat 2025-02-22 06:35:44 UTC RTC time: Wed 2025-02-19 22:52:34 There is a major discrepancy. This is what it ideally looks like'ish: Quote root@build:~/build# timedatectl Local time: Sat 2025-02-22 07:17:15 UTC Universal time: Sat 2025-02-22 07:17:15 UTC RTC time: Sat 2025-02-22 07:17:15 Time zone: Etc/UTC (UTC, +0000) System clock synchronized: yes NTP service: active RTC in local TZ: no Interestingly the 3B seems to have some sort of rtc but I assume its worthless without a puffer battery connected. At least a connector for such is there. 0 Quote
numerik Posted February 22, 2025 Author Posted February 22, 2025 good morning, in fact, is not a "real" orange pi 3b, is a orange pi cm4 inside a big tree tech pad7, i replace the cb1 because is just no powerfull for 4 printers. No sync this morning 😕 numerik@orangepi3b:~$ timedatectl Local time: Sat 2025-02-22 12:05:34 EST Universal time: Sat 2025-02-22 17:05:34 UTC RTC time: Thu 2025-02-20 09:22:42 Time zone: America/New_York (EST, -0500) System clock synchronized: no NTP service: active RTC in local TZ: no 0 Quote
