Don't use kernel 6.12.16 on sunxi64
Go to solution Solved by going,
@going I have a few questions about the kernel sound configuration:
  • why is the SUN50IW9_CODEC configured in two places?
  • do we need CONFIG_SND_SUN8I_CODEC=y and CONFIG_SND_SUN8I_CODEC_ANALOG=y?
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
CONFIG_SND_SUN50IW9_CODEC=m
CONFIG_SND_SUN50I_CODEC_ANALOG=y
CONFIG_SND_SUN4I_I2S=m
CONFIG_SND_SUN4I_SPDIF=m
CONFIG_SND_SUN50I_DMIC=m
CONFIG_SND_SUN9I_HDMI_AUDIO=m
CONFIG_SND_SUN8I_ADDA_PR_REGMAP=y
# end of Allwinner SoC Audio support
CONFIG_SND_SOC_SUNXI_MACH=m
CONFIG_SND_SOC_SUNXI_AHUB_DAM=m
CONFIG_SND_SOC_SUNXI_INTERNALCODEC=m
CONFIG_SND_SOC_SUNXI_SUN50IW9_CODEC=m
# Allwinner SoC Audio support V2
CONFIG_SND_SOC_SUNXI_AAUDIO=m
CONFIG_SND_SOC_SUNXI_AHUB=m
# end of Allwinner SoC Audio support V2
3 минуты назад, Stephen Graf сказал:
Do we need this one?
4 минуты назад, Stephen Graf сказал:
I was adding my Transpeed TV Box patches to official Armbian using kernel 6.12.16. I got this error compiling my dts at this line.
&ahub_dam_mach {
	status = "okay";
I found this was missing in the sun50i-h616.dtsi.
		ahub_dam_mach:ahub_dam_mach {
			compatible = "allwinner,sunxi-snd-mach";
			soundcard-mach,name = "ahubdam";
			status		= "disabled";
			soundcard-mach,cpu {
				sound-dai = <&ahub_dam_plat>;
			soundcard-mach,codec {
Edited by Nick A
Is anybody having success with ilitek LCD display, or SPI in general?
I am trying 6.12 with my orange pi zero 3, but the LCD just remains white.
When I switch back to my microSD with Linux 6.11, it works with no problem (ili9488+ads7846)
Edited by robertoj
Yes. I will try again when I get back home, along with re-including some armbian patches related to SPI
Own reference:
Edited by robertoj
Process of using a kernel config from a file
Copy the config file from /boot folder to build/userpatches
Then rename:
$ mv config-6.11.9-edge-sunxi64 linux-sunxi64-edge.config
cd ..
./compile.sh
I get this compilation error:
[🐳|🔨]     CC [M]  drivers/net/wireless/rtl8811cu/platform/platform_ops.o
[🐳|🔨]     LD [M]  drivers/net/wireless/rtl8811cu/8821cu.o
[🐳|🔨]     AR      drivers/net/built-in.a
[🐳|🔨]     AR      drivers/built-in.a
[🐳|🔨]     AR      built-in.a
[🐳|🔨]     AR      vmlinux.a
[🐳|🔨]   error: the following would cause module name conflict:
[🐳|🔨]     drivers/mfd/ac200.ko
[🐳|🔨]     drivers/net/phy/ac200.ko
[🐳|🔨]   make[2]: *** [Makefile:1875: modules_check] Error 1
[🐳|🔨]   make[2]: *** Waiting for unfinished jobs....
[🐳|🔨]   make[1]: *** [/armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/Makefile:347: __build_one_by_one] Error 2
[🐳|🔨]   make: *** [Makefile:224: __sub-make] Error 2
[🐳|💥] Cleaning up [ please wait for cleanups to finish ]
[🐳|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-e236f45c-7165-44f5-8304-f47c168b3ca3.log.ans ]
It seems that a wifi driver is in 2 folders... I will see which kernel driver I should remove
...first trying removing mfd/ac200
I don't know if has improved anythig... but I see these new build errors:
🐳|🌱] Using kernel config provided by user [ userpatches/linux-sunxi64-edge.config ]
[🐳|🔨]   '/armbian/userpatches/linux-sunxi64-edge.config' -> '/armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/.config'
[🐳|🌱] Considering available RAM for BTF build [ 8709 MiB ]
[🐳|🌱] Enabling eBPF and BTF info [ for fully BTF & CO-RE enabled kernel ]
[🐳|🔨]   # configuration written to .config
[🐳|🌱] Kernel configuration [ linux-sunxi64-edge ]
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[🐳|🌱] Exporting new kernel defconfig [ /armbian/output/config/linux-sunxi64-edge.config ]
[🐳|🔨]   'defconfig' -> '/armbian/output/config/linux-sunxi64-edge.config'
[🐳|🌱] Exporting new kernel config - git commit pending [ /armbian/userpatches/linux-sunxi64-edge.config ]
[🐳|🔨]   'defconfig' -> '/armbian/userpatches/linux-sunxi64-edge.config'
[🐳|🔨]   /armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/.config /armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/.config.armbian.previous differ: byte 105893, line 4195
[🐳|🌱] Kernel configuration changed from previous build [ optimizing for correctness ]
[🐳|🌱] Compiling edge kernel [ 6.12.11 ]
[🐳|🌱] Building kernel [ sunxi64 linux-sunxi64-edge all Image install install modules_install headers_install dtbs_install ]
[🐳|🔨]   Statistics zeroed
[🐳|🔨]   Makefile:219: target 'install' given more than once in the same rule
[🐳|🔨]   /armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/Makefile:343: target 'install' given more than once in the same rule
[🐳|🔨]     SYNC    include/config/auto.conf.cmd
[🐳|🔨]   mkdir -p /armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64/tools/bpf/resolve_btfids && make O=/armbian/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64 subdir=tools/bpf/resolve_btfids --no-print-directory -C bpf/resolve_btfids
[🐳|🔨]     FIXUP IMAGE arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-fixup.scr
[🐳|🔨]     FIXUP IMAGE arch/arm64/boot/dts/allwinner/overlay/sun50i-h5-fixup.scr
[🐳|🔨]     FIXUP IMAGE arch/arm64/boot/dts/allwinner/overlay/sun50i-h6-fixup.scr
[🐳|🔨]   Image Name:
[🐳|🔨]   Created:      Thu Jan 23 16:23:05 2025
[🐳|🔨]   Image Type:   AArch64 Linux Script (uncompressed)
[🐳|🔨]   Data Size:    4127 Bytes = 4.03 KiB = 0.00 MiB
[🐳|🔨]   Load Address: 00000000
[🐳|🔨]   Entry Point:  00000000
[🐳|🔨]   Contents:
[🐳|🔨]      Image 0: 4119 Bytes = 4.02 KiB = 0.00 MiB
[🐳|🔨]   Image Name:
[🐳|🔨]   Contents:
[🐳|🔨]   Image Name:
[🐳|🔨]   Data Size:    3757 Bytes = 3.67 KiB = 0.00 MiB
[🐳|🔨]   Contents:
[🐳|🔨]      Image 0: 3749 Bytes = 3.66 KiB = 0.00 MiB
[🐳|🔨]     INSTALL libsubcmd_headers
[🐳|🔨]     CALL    scripts/checksyscalls.sh
[🐳|🔨]     UPD     kernel/config_data
[🐳|🔨]     CHK     kernel/kheaders_data.tar.xz
[🐳|🔨]     GZIP    kernel/config_data.gz
[🐳|🔨]     CC      kernel/configs.o
[🐳|🔨]     AR      kernel/built-in.a
[🐳|🔨]     AR      built-in.a
[🐳|🔨]     AR      vmlinux.a
[🐳|🔨]     LD      vmlinux.o
[🐳|🔨]     OBJCOPY modules.builtin.modinfo
[🐳|🔨]     GEN     modules.builtin
[🐳|🔨]     MODPOST Module.symvers
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_audio_disable" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_set_audio_interface" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_set_channel_status" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_set_channel_count" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_set_channel_allocation" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_set_audio_infoframe" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   ERROR: modpost: "dw_hdmi_qp_audio_enable" [drivers/gpu/drm/bridge/synopsys/dw-hdmi-qp-i2s-audio.ko] undefined!
[🐳|🔨]   make[3]: *** [scripts/Makefile.modpost:145: Module.symvers] Error 1
[🐳|🔨]   make[2]: *** [Makefile:1889: modpost] Error 2
[🐳|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-14a8896d-b0c4-484a-9bbd-d5bff44e0b27.log.ans ]
[🐳|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ]
[🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-14a8896d-b0c4-484a-9bbd-d5bff44e0b27.log.ans https://paste.armbian.com/log ]
[🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-14a8896d-b0c4-484a-9bbd-d5bff44e0b27.log.ans https://paste.armbian.de/log ]
[🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-14a8896d-b0c4-484a-9bbd-d5bff44e0b27.log.ans https://paste.next.armbian.com/log ]
[🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-14a8896d-b0c4-484a-9bbd-d5bff44e0b27.log.ans https://paste.armbian.eu/log ]
Edited by robertoj
I keep trying to make my ili9488 SPI LCD with Linux 6.12, from the image in NickA's github... with no success so far
Now I have a strong feeling that it is the gpiochip configuration, since I make this test in Linux 6.11 which works with my LCD
With Linux 6.11, the device is gpiochip0
roberto@orangepizero3:~$ sudo cat /sys/kernel/debug/gpio
[sudo] password for roberto:
gpiochip0: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl:
 gpio-71  (                    |dc                  ) out hi
 gpio-73  (                    |interrupt           ) in  hi IRQ
 gpio-74  (                    |pendown             ) in  hi IRQ ACTIVE LOW
 gpio-76  (                    |red:status          ) out lo
 gpio-77  (                    |green:power         ) out hi
 gpio-78  (                    |reset               ) out hi
 gpio-79  (                    |spi1 CS1            ) out hi ACTIVE LOW
 gpio-80  (                    |regulator-usb1-vbus ) out hi
 gpio-166 (                    |cd                  ) in  lo ACTIVE LOW
 gpio-210 (                    |reset               ) out hi ACTIVE LOW
 gpio-226 (                    |BLINK EXAMPLE LINES ) out lo
 gpio-233 (                    |spi1 CS0            ) out hi ACTIVE LOW
With Linux 6.12, the device is gpiochip1
gpiochip1: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl:
 gpio-76  (                    |red:disk-activity   ) out lo
 gpio-77  (                    |green:status        ) out lo
With Linux 6.11, the GPIO lines for reset and command, and the SPI pins, are shown as connected to a function:
roberto@orangepizero3:~$ sudo  cat /sys/kernel/debug/pinctrl/300b000.pinctrl/pinmux-pins
Pinmux settings per pin
Format: pin (name): mux_owner|gpio_owner (strict) hog?
pin 0 (PA0): UNCLAIMED
pin 1 (PA1): UNCLAIMED
pin 2 (PA2): UNCLAIMED
pin 3 (PA3): UNCLAIMED
pin 4 (PA4): UNCLAIMED
pin 5 (PA5): UNCLAIMED
pin 6 (PA6): UNCLAIMED
pin 7 (PA7): UNCLAIMED
pin 8 (PA8): UNCLAIMED
pin 9 (PA9): UNCLAIMED
pin 10 (PA10): UNCLAIMED
pin 11 (PA11): UNCLAIMED
pin 12 (PA12): UNCLAIMED
pin 64 (PC0): device 5010000.spi function spi0 group PC0
pin 65 (PC1): UNCLAIMED
pin 66 (PC2): device 5010000.spi function spi0 group PC2
pin 67 (PC3): device 5010000.spi function spi0 group PC3
pin 68 (PC4): device 5010000.spi function spi0 group PC4
pin 69 (PC5): UNCLAIMED
pin 70 (PC6): UNCLAIMED
pin 71 (PC7): GPIO 300b000.pinctrl:71
pin 72 (PC8): UNCLAIMED
pin 73 (PC9): UNCLAIMED
pin 74 (PC10): GPIO 300b000.pinctrl:74
pin 75 (PC11): UNCLAIMED
pin 76 (PC12): GPIO 300b000.pinctrl:76
pin 77 (PC13): GPIO 300b000.pinctrl:77
pin 78 (PC14): GPIO 300b000.pinctrl:78
pin 79 (PC15): GPIO 300b000.pinctrl:79
pin 80 (PC16): GPIO 300b000.pinctrl:80
pin 96 (PD0): UNCLAIMED
pin 97 (PD1): UNCLAIMED
pin 98 (PD2): UNCLAIMED
pin 99 (PD3): UNCLAIMED
pin 100 (PD4): UNCLAIMED
pin 101 (PD5): UNCLAIMED
pin 102 (PD6): UNCLAIMED
pin 103 (PD7): UNCLAIMED
pin 104 (PD8): UNCLAIMED
pin 105 (PD9): UNCLAIMED
pin 106 (PD10): UNCLAIMED
pin 107 (PD11): UNCLAIMED
pin 108 (PD12): UNCLAIMED
pin 109 (PD13): UNCLAIMED
pin 110 (PD14): UNCLAIMED
pin 111 (PD15): UNCLAIMED
pin 112 (PD16): UNCLAIMED
pin 113 (PD17): UNCLAIMED
pin 114 (PD18): UNCLAIMED
pin 115 (PD19): UNCLAIMED
pin 116 (PD20): UNCLAIMED
pin 117 (PD21): UNCLAIMED
pin 118 (PD22): UNCLAIMED
pin 119 (PD23): UNCLAIMED
pin 120 (PD24): UNCLAIMED
pin 121 (PD25): UNCLAIMED
pin 122 (PD26): UNCLAIMED
pin 123 (PD27): UNCLAIMED
pin 124 (PD28): UNCLAIMED
pin 128 (PE0): UNCLAIMED
pin 129 (PE1): UNCLAIMED
pin 130 (PE2): UNCLAIMED
pin 131 (PE3): UNCLAIMED
pin 132 (PE4): UNCLAIMED
pin 133 (PE5): UNCLAIMED
pin 134 (PE6): UNCLAIMED
pin 135 (PE7): UNCLAIMED
pin 136 (PE8): UNCLAIMED
pin 137 (PE9): UNCLAIMED
pin 138 (PE10): UNCLAIMED
pin 139 (PE11): UNCLAIMED
pin 140 (PE12): UNCLAIMED
pin 141 (PE13): UNCLAIMED
pin 142 (PE14): UNCLAIMED
pin 143 (PE15): UNCLAIMED
pin 144 (PE16): UNCLAIMED
pin 145 (PE17): UNCLAIMED
pin 146 (PE18): UNCLAIMED
pin 147 (PE19): UNCLAIMED
pin 148 (PE20): UNCLAIMED
pin 149 (PE21): UNCLAIMED
pin 150 (PE22): UNCLAIMED
pin 160 (PF0): device 4020000.mmc function mmc0 group PF0
pin 161 (PF1): device 4020000.mmc function mmc0 group PF1
pin 162 (PF2): device 4020000.mmc function mmc0 group PF2
pin 163 (PF3): device 4020000.mmc function mmc0 group PF3
pin 164 (PF4): device 4020000.mmc function mmc0 group PF4
pin 165 (PF5): device 4020000.mmc function mmc0 group PF5
pin 166 (PF6): GPIO 300b000.pinctrl:166
pin 192 (PG0): device 4021000.mmc function mmc1 group PG0
pin 193 (PG1): device 4021000.mmc function mmc1 group PG1
pin 194 (PG2): device 4021000.mmc function mmc1 group PG2
pin 195 (PG3): device 4021000.mmc function mmc1 group PG3
pin 196 (PG4): device 4021000.mmc function mmc1 group PG4
pin 197 (PG5): device 4021000.mmc function mmc1 group PG5
pin 198 (PG6): UNCLAIMED
pin 199 (PG7): UNCLAIMED
pin 200 (PG8): UNCLAIMED
pin 201 (PG9): UNCLAIMED
pin 202 (PG10): UNCLAIMED
pin 203 (PG11): UNCLAIMED
pin 204 (PG12): UNCLAIMED
pin 205 (PG13): UNCLAIMED
pin 206 (PG14): UNCLAIMED
pin 207 (PG15): UNCLAIMED
pin 208 (PG16): UNCLAIMED
pin 209 (PG17): UNCLAIMED
pin 210 (PG18): GPIO 300b000.pinctrl:210
pin 211 (PG19): UNCLAIMED
pin 224 (PH0): device 5000000.serial function uart0 group PH0
pin 225 (PH1): device 5000000.serial function uart0 group PH1
pin 226 (PH2): GPIO 300b000.pinctrl:226
pin 227 (PH3): UNCLAIMED
pin 228 (PH4): UNCLAIMED
pin 229 (PH5): UNCLAIMED
pin 230 (PH6): device 5011000.spi function spi1 group PH6
pin 231 (PH7): device 5011000.spi function spi1 group PH7
pin 232 (PH8): device 5011000.spi function spi1 group PH8
pin 233 (PH9): GPIO 300b000.pinctrl:233
pin 234 (PH10): UNCLAIMED
pin 256 (PI0): device 5020000.ethernet function emac0 group PI0
pin 257 (PI1): device 5020000.ethernet function emac0 group PI1
pin 258 (PI2): device 5020000.ethernet function emac0 group PI2
pin 259 (PI3): device 5020000.ethernet function emac0 group PI3
pin 260 (PI4): device 5020000.ethernet function emac0 group PI4
pin 261 (PI5): device 5020000.ethernet function emac0 group PI5
pin 262 (PI6): UNCLAIMED
pin 263 (PI7): device 5020000.ethernet function emac0 group PI7
pin 264 (PI8): device 5020000.ethernet function emac0 group PI8
pin 265 (PI9): device 5020000.ethernet function emac0 group PI9
pin 266 (PI10): device 5020000.ethernet function emac0 group PI10
pin 267 (PI11): device 5020000.ethernet function emac0 group PI11
pin 268 (PI12): device 5020000.ethernet function emac0 group PI12
pin 269 (PI13): device 5020000.ethernet function emac0 group PI13
pin 270 (PI14): device 5020000.ethernet function emac0 group PI14
pin 271 (PI15): device 5020000.ethernet function emac0 group PI15
pin 272 (PI16): device 5020000.ethernet function emac0 group PI16
But with Linux 6.12 (from NickA's github):
pin 71 (PC7): UNCLAIMED
pin 78 (PC14): UNCLAIMED
pin 198 (PG6): device 5000400.serial function uart1 group PG6
pin 199 (PG7): device 5000400.serial function uart1 group PG7
pin 200 (PG8): device 5000400.serial function uart1 group PG8
pin 201 (PG9): device 5000400.serial function uart1 group PG9
pin 202 (PG10): device wifi-pwrseq function clock group PG10
pin 226 (PH2): UNCLAIMED
pin 228 (PH4): device 5093000.spdif function spdif group PH4
pin 230 (PH6): UNCLAIMED
pin 231 (PH7): UNCLAIMED
pin 232 (PH8): UNCLAIMED
pin 234 (PH10): device 7040000.ir function ir_rx group PH10
I had a pending task to check that all the patches for SPI are included in my build... so I check the source code:
armbian-nickA-20250306/build/patch/kernel/archive/sunxi-6.12/series.conf
And I see that very few patches that are excluded... none of them relate to SPI... I don't know how to make the SPI work in Linux 6.12 as well as it does in Linux 6.12
Am i doing this right?
UPDATE: I tried the same DTS, as shown in https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-208446
with TheGoing build system in his github https://github.com/The-going/armbian-build/tree/main-sunxi-6.12
... and I still see the SPI pins PH6,7,8 as unclaimed
Is anyone able to use the H618 SPI pins in Linux 6.12.x?
UPDATE: in this thread, people discuss the gpiochip0 vs gpiochip1 as a sign that the driver is not "occupying" the GPIO, and a DTS change may be needed
https://forum.armbian.com/topic/49331-nanopi-neo2-v11-how-to-control-otg-port-power-with-gpio-354/#findComment-210992
Edited by robertoj
9 часов назад, robertoj сказал:
Try adding this line compatible = "armbian,spi-dev";
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h616";
	fragment@0 {
		target = <&spi1>;
		__overlay__ {
			status = "okay";
			cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; // PH9=CS0 for lcd, PC15=CS1 for touch
			panel: panel@0 {
				compatible = "panel-mipi-dbi-spi";
				reg = <0>;
P.S. I doubt that I am giving you the right advice.
Edited by going
Add P.S.
Thank you. I will try it
When I helped someone with an orange pi zero 2w (same h618) there were some slight differences to access the spi… I wonder if i need the same changes for my opiz3
Update: the line compatible="armbian,spi-dev"; didnt work...
*The PH6,7,8 still show as unclaimed
*the /dev/input/event0 was not created by ads7846
*the /dev/fb0 was not created
These device files were created with my original DTS... but it appears the drivers think they have an SPI port for themselves, but not really.
UPDATE: here's a difference I saw in the DTS when using Linux 6.11 (spi working) vs Linux 6.12 (spi not working)
6.11:
dtc -I fs -O dts /sys/firmware/devicetree/base
        pinctrl@300b000 {
            vcc-pi-supply = <0x12>;
            clock-names = "apb\0hosc\0losc";
            gpio-controller;
            interrupts = <0x00 0x33 0x04 0x00 0x34 0x04 0x00 0x35 0x04 0x00 0x2b 0x04 0x00 0x36 0x04 0x00 0x37 0x04 0x00 0x38 0x04 0x00 0x39 0x04>;
            clocks = <0x02 0x1a 0x11 0x0b 0x00>;
            compatible = "allwinner,sun50i-h616-pinctrl";
            #interrupt-cells = <0x03>;
            vcc-pc-supply = <0x12>;
            reg = <0x300b000 0x400>;
            phandle = <0x15>;
            #gpio-cells = <0x03>;
            vcc-pf-supply = <0x12>;
            vcc-pg-supply = <0x13>;
            interrupt-controller;
            vcc-ph-supply = <0x12>;
spi1-pins {
                function = "spi1";
                pins = "PH6\0PH7\0PH8";
                phandle = <0x20>;
6.12:
# dtc -I fs -O dts /sys/firmware/devicetree/base
        pinctrl@300b000 {
            vcc-pi-supply = <0x11>;
            gpio-controller;
            clocks = <0x02 0x1a 0x10 0x0b 0x00>;
            vcc-pc-supply = <0x11>;
            phandle = <0x14>;
            vcc-pf-supply = <0x11>;
            vcc-pg-supply = <0x12>;
            vcc-ph-supply = <0x11>;
            spi1-pins {
                function = "spi1";
                phandle = <0x50>;
I see there's a difference in phandles... but maybe it is meant to be that way... since I see differences in spi0, which works
UPDATE: I tried with linux 6.13.7... it still didn't work.
UPDATE: when comparing the Device Trees, focusing in the SPI branch:
6.11 (working):
        spi@5011000 {
            pinctrl-names = "default";
            #address-cells = <0x01>;
            pinctrl-0 = <0x20>;
            clock-names = "ahb\0mod";
            resets = <0x02 0x1d>;
            interrupts = <0x00 0x0d 0x04>;
            clocks = <0x02 0x50 0x02 0x4e>;
            #size-cells = <0x00>;
            dma-names = "rx\0tx";
            compatible = "allwinner,sun50i-h616-spi\0allwinner,sun8i-h3-spi";
            status = "okay";
            reg = <0x5011000 0x1000>;
            phandle = <0x6a>;
            dmas = <0x1b 0x17 0x1b 0x17>;
            cs-gpios = <0x15 0x07 0x09 0x00 0x15 0x02 0x0f 0x00>;
6.12 (not working)
        spi@5011000 {
            status = "okay";
            phandle = <0x6f>;
            dmas = <0x1a 0x17 0x1a 0x17>;
            cs-gpios = <0x14 0x07 0x09 0x00 0x14 0x02 0x0f 0x00>;
Notice that in 6.12, the properties pinctrl-names and pinctrl-0 do not exist, but I used the same ili9488-ads7846.dts in both if them...
Does anybody know what may be happening? Or what's needed to add what is missing?
I added pinctrl-names = "default"; and pinctrl-0 = <0x20>; and I see these properties in my resulting device tree... but I still dont see PH6,7,8 owned, still unclaimed
Edited by robertoj
18 часов назад, robertoj сказал:
This means that the missing pins should be written something like this:
	fragment@0 {
		target = <&spi1>;
		__overlay__ {
			status = "okay";
			#address-cells = <1>;
			#size-cells = <0>;
			pinctrl-0 = <&spi1_pins>, <&spi1_cs0_pin>, <&spi1_cs1_pin>;
Thank you for the suggestion :)
At first it didn't work... then I tried:
	fragment@0 {
		target = <&spi1>;
		__overlay__ {
			status = "okay";
			#size-cells = <0>;
			pinctrl-0 = <&spi1_pins>;
Because I use non default CS pins
The ili9488 LCD is now working in linux 6.13 :D... the touch screen is also working with the evtest command :)
I will post the whole DTS in my ili9488 thread :)
Edited by robertoj
Help! My DTS, which used to work with 6.13 and 6.12 from the unofficial repo's from NickA and Going... are not working in the official armbian linux 6.13
This is an issue of not owning the DC and RESET pins, as seen in
PC7 and PC14 need to show this:
dmesg shows this error:
$ dmesg|grep spi
[    1.911366] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.911650] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.917726] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.918005] sun6i-spi 5011000.spi: Error applying setting, reverse things back
The DTS I used is:
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            pinctrl-names = "default"; //new for linux 6.13
            pinctrl-0 = <&spi1_pins>; //new for linux 6.13
            panel: panel@0 {
                reg = <0>;
                spi-max-frequency = <40000000>;
                width-mm=<84>;
                height-mm=<56>;
                reset-gpios = <&pio 2 14 0>; // PC14
                dc-gpios = <&pio 2 7 0>; // PC7
                write-only;
                format = "b6x2g6x2r6x2";
                panel-timing {
                    hactive = <480>;
                    vactive = <320>;
                    hback-porch = <0>;
                    vback-porch = <0>;
                    clock-frequency = <0>;
                    hfront-porch = <0>;
                    hsync-len = <0>;
                    vfront-porch = <0>;
                    vsync-len = <0>;
            ads7846: ads7846@1 {
                compatible = "ti,ads7846";
                reg = <1>;
                spi-max-frequency = <1000000>;
                interrupt-parent = <&pio>;
                interrupts = <2 10 2>; /* PC10 - IRQ */
                pendown-gpio = <&pio 2 10 1>; /* PC10 */
                /* OPTIONS */
                ti,x-min = /bits/ 16 <0>;
                ti,y-min = /bits/ 16 <0>;
        ti,x-max = /bits/ 16 <0xFFF>;
        ti,y-max = /bits/ 16 <0xFFF>;
                ti,pressure-min = /bits/ 16 <0>;
                ti,pressure-max = /bits/ 16 <0xFFF>;
                ti,x-plate-ohms = /bits/ 16 <400>;
                ti,swap-xy = <1>;
I think anyone with Linux 6.13 (armbian official) can try this DTS without an LCD connected to the orange pi zero 3... at this time, I only need that the PC7 and PC14 are owned by the SPI driver.
Edited by robertoj
When I start from scratch with TheGoing repo, linux 6.13.7, I apply my DTS, copy my firmware, and I get this DT (snipped in the area that counts)
$ dtc -I fs -O dts /sys/firmware/devicetree/base
        spi@5011000 {
            pinctrl-0 = <0x57>;
            status = "okay";
            phandle = <0x76>;
            dmas = <0x1c 0x17 0x1c 0x17>;
            cs-gpios = <0x16 0x07 0x09 0x00 0x16 0x02 0x0f 0x00>;
            panel@0 {
                width-mm = <0x54>;
                spi-max-frequency = <0x2625a00>;
                reset-gpios = <0x16 0x02 0x0e 0x00>;
                dc-gpios = <0x16 0x02 0x07 0x00>;
                write-only;
                reg = <0x00>;
                phandle = <0xa3>;
                height-mm = <0x38>;
                panel-timing {
                    vfront-porch = <0x00>;
                    vback-porch = <0x00>;
                    hsync-len = <0x00>;
                    vactive = <0x140>;
                    clock-frequency = <0x00>;
                    hactive = <0x1e0>;
                    vsync-len = <0x00>;
                    hback-porch = <0x00>;
                    hfront-porch = <0x00>;
            ads7846@1 {
                ti,pressure-min = [00 00];
                ti,y-max = [0f ff];
                ti,pressure-max = [0f ff];
                interrupts = <0x02 0x0a 0x02>;
                spi-max-frequency = <0xf4240>;
                interrupt-parent = <0x16>;
                ti,x-min = [00 00];
                pendown-gpio = <0x16 0x02 0x0a 0x01>;
                ti,x-plate-ohms = [01 90];
                reg = <0x01>;
                ti,x-max = [0f ff];
                phandle = <0xa4>;
                ti,y-min = [00 00];
                ti,swap-xy = <0x01>;
And the LCD works.
And when I start from scratch from the Armbian repo, linux 6.13.11, I apply my DTS, copy my firmware, and get this Device Tree:
        spi@5011000 {
            pinctrl-0 = <0x62>;
            status = "okay";
            phandle = <0x81>;
            dmas = <0x22 0x17 0x22 0x17>;
            cs-gpios = <0x1c 0x07 0x09 0x00 0x1c 0x02 0x0f 0x00>;
            panel@0 {
                width-mm = <0x54>;
                reset-gpios = <0x1c 0x02 0x0e 0x00>;
                dc-gpios = <0x1c 0x02 0x07 0x00>;
                write-only;
                reg = <0x00>;
                phandle = <0xae>;
                height-mm = <0x38>;
                panel-timing {
                    hsync-len = <0x00>;
                    vactive = <0x140>;
                    hactive = <0x1e0>;
                    vsync-len = <0x00>;
            ads7846@1 {
                ti,y-max = [0f ff];
                interrupt-parent = <0x1c>;
                ti,x-min = [00 00];
                pendown-gpio = <0x1c 0x02 0x0a 0x01>;
                reg = <0x01>;
                ti,x-max = [0f ff];
                phandle = <0xaf>;
                ti,y-min = [00 00];
But the GPIO pins PC7 and PC14 appear unclaimed (as seen in previous post), and the LCD remains white.
The linux build configs are practically the same (side in 6.13.11 has the error in SPI configuration)
$ diff config-6.13.7-going config-6.13.11-official
3c3
< # Linux/arm64 6.13.7 Kernel Configuration
> # Linux/arm64 6.13.11 Kernel Configuration
20a21
> CONFIG_LD_CAN_USE_KEEP_IN_OVERLAY=y
3012a3014
> CONFIG_RTL8189FS=m
5806d5807
< CONFIG_SND_SUN50IW9_CODEC=m
5820d5820
< CONFIG_SND_SOC_SUNXI_SUN50IW9_CODEC=m
I found that the TheGoing repo has a two less patches applied... the zero 2w seems more relevant
roberto@linux:~/armbian-theGoing/armbian-build/patch/kernel/archive/sunxi-6.13$ diff series.armbian ~/armbian-apr2025/build/patch/kernel/archive/sunxi-6.13/series.armbian
156c156
< -    patches.armbian/enable-TV-Output-on-OrangePi-Zero-LTE.patch
168,169c168,170
<     patches.armbian/arm64-dts-h616-8-Add-overlays-i2c-234-ph-pg-uart-25-ph-pg.patch
< -    patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch
>     patches.armbian/arm64-dts-sun50i-h616-add-pwm-nodes-support.patch
>     patches.armbian/arm64-dts-h616-8-Add-overlays-i2c-pwm-uart.patch
IMPORTANT:
I just added "-" before "patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch" in the:
build/patch/kernel/archive/sunxi-6.13/series.conf file, and I finally have the ili9488 LCD working with my ili9488-ads7846 DTS
My SBC is the OrangePiZero 3, and I select that specific SBC in the menuconfigs after starting "./compile.sh"
Edited by robertoj
