Hi can anyone advise if they have come accross this issue.
so somehow HDMIRX seems to be the hdmi input controller starts to freak out for no reason
there is nothing plugged into it EVER and will randomly start to outpur this to console
im thinking maybe the HDMIRX is faulty and want to remove it, I have tried removing it
removed the DTB , decompiled and edited and removed it from DTB, tied to blacklist it but with no effect
it does not stop spamming and the device
[ 89.603095] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_phy_register_write wait cr write done failed!
[ 89.613765] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_phy_register_write wait cr write done failed!
[ 89.624917] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_phy_register_write wait cr write done failed!
[ 89.635554] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_phy_register_write wait cr write done failed!
[ 89.704256] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_controller_init wait timer base lock failed!
not for my last attemt i want to check if anyone has the .config for the kernel and perhaps knows what the driver / module is called
this way I am guaranteed i will not see it again.
Note: I have reinsatlled multiple distros to check and it keeps happening randomly
so any input on this would be great.
Much appreciated and thanks in advance.
