Is it possible to generate ISO8859-2 locale?
Go to solution Solved by Werner,
I read about Debian/Ubuntu, that — as the Armbian — in general have all sorts of UTF-8 locales installed by default, it is possible to generate ISO8859-2 locales anyway by using a 'locale-gen' tool (found such suggestion here ). But there isn't locale-gen in Armbian, it seems (Armbian v25.2.2).
Can it be installed from some repo, or maybe it's possible to generate ISO8859-2 locales some alternative way? If so — how do i do that?
Edited by Bugger
typo
  • Solution
Could you check if CONFIG_NLS_ISO8859_2 is enabled in your kernel config?
The package is locales I think.
That it is not installed tells me you are most likely using a Minimal/IoT image which comes with the absolute bare minimum to have a working system. Designed for advanced users knowing how to install such tools afterwards if needed.
In config-6.6.75-current-sunxi file there I can see CONFIG_NLS_ISO8859_2=m
Indeed it was 'locales' package that was missing. Thanks!
Edited by Bugger
solved
