Ed van den Enden Posted March 17 Posted March 17 Hardware: Banana pi M2 Zero OS Armbian_community_25.5.0-trunk.185_Bananapim2zero_bookworm_current_6.6.75_minimal pyGPIO - A 'more general' python GPIO library from "chwe". Question: Could the below python script work for a safe "shutdown" of the MBI M2Z? _____________________________________________________________________________ #!/usr/bin/python # shutdown/reboot Banana Pi M2 Zero with pushbutton from pyGPIO.gpio import gpio, connector from subprocess import call from datetime import datetime import time # Initialize GPIO gpio.init() # Pushbutton connected to this GPIO pin shutdownPin = connector.GPIOp11 # Adjust based on your wiring # If button pressed for at least this long, shut down. If less, reboot. shutdownMinSeconds = 3 # Button debounce time in seconds debounceSeconds = 0.1 # Set up the GPIO pin as input with pull-up resistor gpio.setcfg(shutdownPin, gpio.INPUT) gpio.pullup(shutdownPin, gpio.PULLUP) buttonPressedTime = None def buttonStateChanged(pin): global buttonPressedTime if gpio.input(pin) == gpio.LOW: # Button is down (active low) if buttonPressedTime is None: buttonPressedTime = datetime.now() else: # Button is up if buttonPressedTime is not None: elapsed = (datetime.now() - buttonPressedTime).total_seconds() buttonPressedTime = None if elapsed >= shutdownMinSeconds: # Button pressed for more than specified time, shutdown call(['shutdown', '-h', 'now'], shell=False) # Uncomment the following lines if you want to enable reboot functionality # elif elapsed >= debounceSeconds: # # Button pressed for a shorter time, reboot # call(['shutdown', '-r', 'now'], shell=False) # Subscribe to button presses gpio.set_irq(shutdownPin, gpio.BOTH, buttonStateChanged) while True: # Sleep to reduce unnecessary CPU usage time.sleep(5) 0 Quote
