Rock3A Armbian how to enable SPI3
Go to solution Solved by M. Hatef,
Hi
I have spent couple of days to enable the SPI3 (the only SPI that has been routed to the 40-pin header) on Rock3A, but no success.
I am trying to enable SPI3M1C0 with following pins on my Rock 3A
GPIO4_C2 (CLK), GPIO4_C3 (MOSI), GPIO4_C5 (MISO), and GPIO4_C6 (CS0).
I am out of idea, try different overlays but still not able to enable them.
I used this overlay from this repo
https://github.com/radxa/overlays/blob/main/arch/arm64/boot/dts/rockchip/overlays/rk3568-spi3-m1-cs0-spidev.dts
I expect to see “/dev/spidev3.0” but nothing appeared.
I have already added 2 overlays, 1 for 1-wire, and the other for I2C, and they are working now.
Here some info from my Rock3A:
root@rock-3a:~# uname -a
Linux rock-3a 6.12.19-current-rockchip64 #2 SMP PREEMPT Thu Mar 13 12:02:20 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
rroot@rock-3a:~# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=both
extraargs=cma=256M
overlay_prefix=rk35xx
fdtfile=rockchip/rk3568-rock-3a.dtb
rootdev=UUID=8a5d56b7-1e1b-49b6-8384-5ef8a0460c96
rootfstype=ext4
overlays=rockchip-rk3568-spi3-m1-cs0-spidev
param_spidev_spi_bus=3
param_spidev_max_freq=10000000
user_overlays=rk3568-i2c3m0-enable rk3568-w1-gpio3-a2
root@rock-3a:~# lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Armbian 25.2.3 noble
Release:	24.04
Codename:	noble
# nothinig shown in the kernel log
root@rock-3a:~# dmesg | grep -i spi
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
root@rock-3a:~# lsmod | grep -i spi
spidev                 24576  0
spi_rockchip_sfc       16384  0
root@rock-3a:~# ls -d /proc/device-tree/spi*
/proc/device-tree/spi@fe300000  /proc/device-tree/spi@fe610000  /proc/device-tree/spi@fe620000  /proc/device-tree/spi@fe630000  /proc/device-tree/spi@fe640000
# this is from my live dts. it shows the SPI is enabled, but I still cannot see it in my file system "/dev/spi*"
	spi@fe640000 {
		pinctrl-names = "default\0high_speed";
		#address-cells = <0x01>;
		pinctrl-0 = <0x22e 0x22d>;
		clock-names = "spiclk\0apb_pclk";
		interrupts = <0x00 0x6a 0x04>;
		clocks = <0x0f 0x158 0x0f 0x157>;
		#size-cells = <0x00>;
		dma-names = "tx\0rx";
		compatible = "rockchip,rk3568-spi\0rockchip,rk3066-spi";
		pinctrl-1 = <0x22e 0x264>;
		status = "okay";
		max-freq = <0x2faf080>;
		reg = <0x00 0xfe640000 0x00 0x1000>;
		phandle = <0x12b>;
		dmas = <0x27 0x1a 0x27 0x1b>;
		spidev@0 {
			spi-max-frequency = <0x2faf080>;
			compatible = "rockchip,spidev";
			status = "okay";
			reg = <0x00>;
root@rock-3a:~# ls -tlhr /dev/spi*
ls: cannot access '/dev/spi*': No such file or directory
would be appreciate it if anyone can help.
Thanks
Edited by M. Hatef
  • M. Hatef changed the title to Rock3A Armbian how to enable SPI3
@Werner
Thanks,
I compiled the one from the mainline kernel you shared. I am still not seeing anything on /dev/spi*
I also hooked up the serial debugger to collect kernel logs
I cannot see any issue with loading the overlay. here is the kernel log snippet
## Executing script at 00c00000
Boot script loaded from mmc 1:1
reading /armbianEnv.txt
499 bytes read in 2 ms (243.2 KiB/s)
reading /uInitrd
23359976 bytes read in 1938 ms (11.5 MiB/s)
reading /Image
37335552 bytes read in 3095 ms (11.5 MiB/s)
reading /dtb/rockchip/rk3568-rock-3a.dtb
124861 bytes read in 17 ms (7 MiB/s)
reading /overlay-user/rk3568-spi3-m1-cs0-spidev.dtbo
1053 bytes read in 3 ms (342.8 KiB/s)
Applying user provided DT overlay rk3568-spi3-m1-cs0-spidev.dtbo
reading /overlay-user/rk3568-i2c3m0-enable.dtbo
398 bytes read in 2 ms (194.3 KiB/s)
Applying user provided DT overlay rk3568-i2c3m0-enable.dtbo
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
No misc partition
looks like it was successfully read and applied. but still there is no SPI device available.
Here is my armbianEnv.txt for reference. I am not sure what I am missing.
verbosity=1
bootlogo=false
console=both
extraargs=cma=256M
rootfstype=ext4
#overlays=rockchip-rk3568-spi3-m1-cs0-spidev
#param_spidev_spi_bus=3
#param_spidev_max_freq=10000000
param_spidev_spi_bus=1
#user_overlays=rk3568-i2c3m0-enable rk3568-w1-gpio3-a2  rk3568-spi3-m1-cs0-spidev
user_overlays=rk3568-spi3-m1-cs0-spidev rk3568-i2c3m0-enable
Hi @Werner
I ran the command, it looks like it uploads multiple kernel boot log. so I the most bottom one is the last kernel log I am dealing with.
https://paste.armbian.de/fexaxufalu
Last night, I played with dts, and I got the SPI3 enumerated at /dev/spi3. but it still not working. I mean when I run a script to use the SPI3, I cannot see any clock gets generated on SPI3.CLK.
Here is the dts file:
(venv) root@rock-3a:~# cat my-spi3-overlay.dts
/dts-v1/;
/plugin/;
    compatible = "rockchip,rk3568"; /* Update to match your SoC */
    fragment@0 {
        target = <&spi3>; /* Correct SPI3 node */
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            pinctrl-names = "default";
            pinctrl-0 = <&spi3m1_pins>; /* Reference correct pin configuration */
            status = "okay"; /* Enable SPI3 */
            spidev@0 {
                compatible = "armbian,spi-dev";
                reg = <0x00>;
                spi-max-frequency = <5000000>;
                status = "okay";
    fragment@1 {
        target = <&pinctrl>; /* Ensure this matches your pin controller node */
        __overlay__ {
            spi3m1_pins: spi3m1-pins {
                rockchip,pins = <
                    4 18 3 0 /* GPIO4_C2 as SPI3_CLK_M1 */
                    4 19 3 0 /* GPIO4_C3 as SPI3_MOSI_M1 */
                    4 21 3 0 /* GPIO4_C5 as SPI3_MISO_M1 */
                    4 22 3 0 /* GPIO4_C6 as SPI3_CS0_M1 */
here is the armbianEnv.txt
(venv) root@rock-3a:~# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=both
extraargs=cma=256M
rootfstype=ext4
#overlays=rockchip-rk3568-hk-spi-spidev
user_overlays=rk3568-i2c3m0-enable rk3568-w1-gpio3-a2 my-spi3-overlay
param_spidev_spi_cs=0
Here is the logic analyzer output while the script was running. noted CS pin is alway Low and other pins are always High no matter what I am running the script.
I have also attached the script that I am running to test out the SPI3
adc_reader.py
  • Solution
ok I got it working by modifying my dts file.
I am sharing it here for those who face the issue. So you dont have to waste days while pulling your hairs :)
/dts-v1/;
/plugin/;
    fragment@0 {
        __overlay__ {
            #size-cells = <0>;
            pinctrl-0 = <&spi3m1_pins &spi3m1_cs0>; /* Reference correct pin configuration */
            spidev@0 {
                reg = <0x00>;
                status = "okay";
As guessed you did not switch to vendor kernel and tried using a vendor kernel overlay with mainline kernel. But glad you figured it out what changes are necessary in order to make it work.
Feel free to send the working overlay the build framework so it is included by default. mainline still lacks lots of overlays.
