mantabernd Posted September 2, 2017 Share Posted September 2, 2017 Hi, I'm using my NanoPi NeoAir as a bluetooth streaming sink and as a webserver for several configurations and monitoring of the device. Bluetooth works fine as long as I don't disable the powersafe mode of wifi. Even in powersafe mode the bluetooth performance is not the best. If I disable wifi at all the bluetooth performance is great. My system is: Ubuntu 16.04.3 LTS 4.11.2 iwconfig: wlan0 IEEE 802.11 ESSID:"Teebeutel" Mode:Managed Frequency:2.412 GHz Access Point: 2C:41:38:FB:D7:30 Bit Rate=54 Mb/s Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=43/70 Signal level=-67 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 how I disable powersafe: sudo /sbin/iwconfig wlan0 power off Bluetooth is barely usable when powersafe is off... Any idea? Is this a driver problem? Thanks for your support. Regards Bernhard Link to comment Share on other sites More sharing options...
Igor Posted September 3, 2017 Share Posted September 3, 2017 Bluetooth and wireless are sharing one antenna stream, channels are close and chip package is low cost. Problems of this kind are expected. When Wireless is transmitting with full power it omits Bluetooth. You can try with optimising wifi: if changing channels, lowering wifi tx power and using G mode effects? With power management off. Link to comment Share on other sites More sharing options...
