Armbian on H96 Max Ultra 4K (RK3318) stuck in boot mode
Hi everyone,
I'm facing an issue with my Armbian setup on an H96 Max Ultra 4K (RK3318). The system boots up normally and works fine for a while, but after running for some time, it completely freezes and becomes unresponsive. I have to power cycle the device to get it running again. This issue keeps happening consistently after some time, and I’m not sure what's causing it.
Here are a few details about my setup:
Board model: H96 Max Ultra 4K (RK3318)
Armbian version: Armbian_24.11.0_rockchip_rk3318-box_bookworm_6.1.114_server_2024.11.01.img
SD card format: BTRFS
Things I've tried so far:
Checking the power supply to ensure it's stable and sufficient.
Re-imaging the SD card with a fresh Armbian installation.
Monitoring logs, but I haven’t found any obvious errors before the system hangs.
Does anyone have any idea what might be causing this issue or how to resolve it? Any help or suggestions would be greatly appreciated!
Thanks in advance!
I have the same device, it never happened, set the power mode
my ROM: https://drive.google.com/file/d/1DzerEwo8NRoLF0kxuvD11IGO3mXdxo6K/view?usp=sharing
On 5/28/2024 at 5:43 PM, Hqnicolas said:
Fix CPU clock
sudo -i
# See policy to see how CPUs are grouped.
echo conservative > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo conservative > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
echo conservative > /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor
exit
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
Check GPU Frequency
ls /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/cur_freq
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/min_freq
cat /sys/devices/platform/fde60000.gpu/devfreq/fde60000.gpu/max_freq
Check CPU frequency
ls /sys/devices/system/cpu/cpu0/cpufreq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq
Edited by Hqnicolas
