Björn Eiríksson Posted March 26, 2025 Posted March 26, 2025 Where has enabling things like I2C moved to ? I do not see it any more in armbian-config (at least on the Orange Pi 5 plus image) Thanks 0 Quote
Werner Posted March 27, 2025 Posted March 27, 2025 armbian-config is still able to handle overlays, though in some cases it might not works. Not an issue though since it can be easily done manually as well. Check /boot/dtb/rockchip/overlay for the available overlays. You need the rk3588 ones. Check if the overlay_prefix in /boot/armbianEnv.txt is correct. Might be necessary to change to rockchip. Then simply add the overlays you want like this (example): overlays=rk3588-i2c8-m2 0 Quote
