Erez Alster Posted March 28, 2025 Posted March 28, 2025 Can you tell me how I'm able to enable PWM? I'm not able to see any of them in the armbian-config overlay management 0 Quote
Solution Werner Posted March 28, 2025 Solution Posted March 28, 2025 Check /boot/dtb/rockchip/overlay for available overlays. If you are using mainline kernel overlays might be missing. Use vendor kernel in this case. If armbian-config fails for adding simply add them manually with overlays= in /boot/armbianEnv.txt 0 Quote
