Hi all!
I need to install other packages and make a custom configuration of OS.
Can I do at image building time:
- Remove Armbian packages
- Add other packages
- Save configs at location /etc/
- Setup user name + password and Bash profiles
5 hours ago, tkaiser said:
Do not use external hooks, only gods know how well they work If you plan to maintain your on distro for a specific device, just remove whatever unneeded code from .sh files to make them simpler and more readable.
10 hours ago, alexparser said:
This will work with old kernel 3.4.xxx?
What order of *.sh files execution?
BR,
Armbian uses old kernels. The build process starts with the ../compile.sh file.  Packages to install is defined in the configuration.sh file.  Additional files are written in the distributions.sh file.
