Mainline u-boot w/ sunxi-3.4 kernel
Hi,
Anyone here ever tried to build a mainline uboot for sunxi-3.4 kernel.
As mentioned here v2015.10 support NAND spl.
https://linux-sunxi.org/Mainline_U-Boot#v2015.10
I'm in the first part of doing it, but unfortunately I'm always stuck with this error.
  OBJCOPY examples/standalone/hello_world.srec
  OBJCOPY examples/standalone/hello_world.bin
  LDS     u-boot.lds
  LD      u-boot
  DTC     arch/arm/dts/sun7i-a20-ainol-aw1.dtb
In file included from arch/arm/dts/sun7i-a20-ainol-aw1.dts:10:0:
arch/arm/dts/sun7i-a20.dtsi:47:54: fatal error: dt-bindings/interrupt-controller/arm-gic.h: No such file or directory
 #include <dt-bindings/interrupt-controller/arm-gic.h>
compilation terminated.
make[2]: *** [arch/arm/dts/sun7i-a20-ainol-aw1.dtb] Error 1
make[1]: *** [arch-dtbs] Error 2
make: *** [dts/dt.dtb] Error 2
Maybe anyone here already try this, it can help a lot to speed-up the process.
Thanks
Just an idea how to fix this. Perhaps (I haven't check the code) the device tree for sun7i-a20-ainol-aw1.dts is faulty - remove it from the arch/arm/dts/Makefile ... and try to compile again.
Hi Igor,
That solves the problem. Then another error occurs.
LDS u-boot.lds
LD u-boot
Device Tree Source is not correctly specified.
Please define 'CONFIG_DEFAULT_DEVICE_TREE'
or build with 'DEVICE_TREE=' argument
make[1]: *** [arch/arm/dts/sun7i-a20-cubieboard2.dtb] Error 1
I apologize for this newbie question.
Thanks.
Hi Igor,
Yes, I did. Exact sequence below.
root@ubuntu1404-VirtualBox:/home/ubuntu1404/Desktop/LITE/u-boot# make clean
root@ubuntu1404-VirtualBox:/home/ubuntu1404/Desktop/LITE/u-boot# make mrproper
root@ubuntu1404-VirtualBox:/home/ubuntu1404/Desktop/LITE/u-boot# make CROSS_COMPILE=arm-linux-gnueabihf- Cubieboard2_defconfig
I attached the  log file.
Thanks.
complete_logs.txt
