Robert Pace Posted April 6 Posted April 6 Is there a list of Armbian Kernels that include EMMC support? I've tried the vendor kernel build 6.1.99, the LTS 6.12.21, and Bleeding Edge 6.14.0 to find they all lack the mmcblk0 under /dev/ , and lack overlays for it under /boot/dtb/rockchip/overlays/. I have wiped SPI and SPNOR without success. 0 Quote
Werner Posted April 6 Posted April 6 I just put a random emmc module on my 5+ with vendor kernel and got detected as /dev/mmcblk0. So...cannot reproduce 0 Quote
eselarm Posted April 6 Posted April 6 (edited) 4 hours ago, Robert Pace said: I have wiped SPI and SPNOR without success. I assume 'without success' refers to: all zeros in 'SPI flash chip'. There could be other effects as well. All Armbian Rockchip kernels have eMMC (just '/dev/mmcblk*' essentially) fixed/builtin in the kernel so in vmlinuz, no initrd or overlays needed. I don't know OP5+ HW, but note that you can have 3 bootable storage devices on a Rockchip based SBC where U-Boot can be loaded from. So besides SPI, also eMMC and/or SD-card can contain a U-Boot bootloader (see first 16MiB of those devices). If so, then the question is what version of U-Boot? Besides lacking a mmcblk dev, like is the case for example if I use an old version of EDK2 UEFI on my NanoPi-R6C (RK3588s) on the eMMC(!), It might be that a mainline U-Boot version does not work with vendor kernel. I had that for my Rock3A for example (kernel crash). Edited April 6 by eselarm 0 Quote
Robert Pace Posted April 6 Author Posted April 6 The wiping of SPI & SPNOR were themselves successful processes, the access to EMMC was not. I note this is the 32gb ram variant of the Orange Pi 5 Plus. I have also tried multiple 256 GB EMMC modules, each zeroed out via RKDevTool 3.19. Quote Linux Atlas 6.1.99-vendor-rk35xx #1 SMP Wed Mar 19 11:16:36 UTC 2025 aarch64 GNU/Linux Quote NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 18.2T 0 disk └─sda1 8:1 0 18.2T 0 part /mnt/Elements sdb 8:16 0 7.3T 0 disk └─sdb1 8:17 0 7.3T 0 part /mnt/MyBook mtdblock0 31:0 0 16M 0 disk zram0 252:0 0 15.5G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 1.8T 0 disk └─nvme0n1p1 259:1 0 1.8T 0 part /var/log.hdd / Quote root@Atlas:/dev# ls -l m* crw-rw-rw- 1 root root 10, 118 Apr 5 20:19 mali0 crw-r----- 1 root kmem 1, 1 Apr 5 20:19 mem crw------- 1 root root 240, 0 Apr 5 20:19 mpp_service crw------- 1 root root 90, 0 Apr 5 20:19 mtd0 crw------- 1 root root 90, 1 Apr 5 20:19 mtd0ro brw-rw---- 1 root disk 31, 0 Apr 5 20:23 mtdblock0 Quote root@Atlas:/dev# strings /dev/mtd0 | grep U-Boot\ 2 U-Boot 2017.09-armbian-2017.09-S3ba9-P0ef3-Hbe75-Ve691-Bb703-R448a U-Boot 2017.09-armbian-2017.09-S3ba9-P0ef3-Hbe75-Ve691-Bb703-R448a (Mar 11 2025 - 08:33:40 +0000) Quote --------------------------------------------------------------------------- Generated with Armbian(tm) build framework https://github.com/armbian/build --------------------------------------------------------------------------- Vendor: Armbian-unofficial Revision: 25.05.0-trunk Board: Orangepi5-plus Kernel: Linux 6.1.99 (vendor) Build date: 28.03.2025 Sources: https://github.com/armbian/build Sources rev: 756dff9 Authors: https://www.armbian.com/authors Maintainer: John Doe <john.doe@somewhere.on.planet> Support: https://community.armbian.com/ --------------------------------------------------------------------------- Partitioning configuration: gpt offset: 16 Boot partition type: (none) (0 MB) Root partition type: ext4 CPU configuration: 408000 - with ondemand --------------------------------------------------------------------------- Let me know if any other details would be handy in the diagnosis of this issue. https://paste.armbian.com/rakukijuju 0 Quote
eselarm Posted April 6 Posted April 6 2 hours ago, Robert Pace said: root@Atlas:/dev# strings /dev/mtd0 | grep U-Boot\ 2 U-Boot 2017.09-armbian-2017.09-S3ba9-P0ef3-Hbe75-Ve691-Bb703-R448a So SPI flash is not all zeros, you have it filled with that U-Boot version. In the log I see mmc0, but I might be that this old U-Boot in SPI flash somehow hides it. I would make sure you boot a mainline U-Boot. You need a serial console cable to check which U-Boot from which device is loaded and used. 0 Quote
Robert Pace Posted April 6 Author Posted April 6 20 minutes ago, eselarm said: So SPI flash is not all zeros, you have it filled with that U-Boot version. In the log I see mmc0, but I might be that this old U-Boot in SPI flash somehow hides it. I would make sure you boot a mainline U-Boot. You need a serial console cable to check which U-Boot from which device is loaded and used. It was wiped, and U-Boot from the sdcard (from a armbian build image) so the unit can boot to NVME. 0 Quote
eselarm Posted April 6 Posted April 6 6 minutes ago, Robert Pace said: U-Boot from the sdcard (from a armbian build image) Yeah what version... You need to be more precise, but I guess you don't have a serial console/debug cable connected so you can show at least yourself what the board is doing. This way, at least I can't help you. Also you can interrupt U-Boot and via commands (see U-Boot help on various websites) check for existence of storage interfaces/devices. It is before the kernel is loaded. 0 Quote
Robert Pace Posted April 6 Author Posted April 6 32 minutes ago, eselarm said: You need to be more precise, but I guess you don't have a serial console/debug cable connected so you can show at least yourself what the board is doing. This way, at least I can't help you. Also you can interrupt U-Boot and via commands (see U-Boot help on various websites) check for existence of storage interfaces/devices. It is before the kernel is loaded. I used the following image on a microsd card as the source of the bootloader. Quote Generated with Armbian(tm) build framework https://github.com/armbian/build --------------------------------------------------------------------------- Vendor: Armbian-unofficial Revision: 25.05.0-trunk Board: Orangepi5-plus Kernel: Linux 6.1.99 (vendor) Build date: 01.03.2025 Sources: https://github.com/armbian/build Sources rev: 2b7cb0d1a Authors: https://www.armbian.com/authors Maintainer: John Doe <john.doe@somewhere.on.planet> Support: https://community.armbian.com/ --------------------------------------------------------------------------- Partitioning configuration: gpt offset: 16 Boot partition type: (none) (0 MB) Root partition type: ext4 CPU configuration: 408000 - with ondemand --------------------------------------------------------------------------- I note that most of the armbian website's Orange Pi 5 Plus images either fail to support EMMC for me, or lack I2C-2 support in the overlays. I thought perhaps this issue is due to me using a 32 gb ram variant of the SBC, but the missing EMMC is present on 16gb variants as well. I reinstalled a ubuntu environment and compiled the vendor 6.1.99 image for Orange Pi 5 Plus (Debian Bookworm, Full Desktop image), and it boots fine, but no EMMC. A boot from an orangepi5.org debian 12 image does include emmc support, and i2c2-m0 functionality, but does lack functional xrdp. 0 Quote
Werner Posted April 7 Posted April 7 I am not 100% certain but I think one of these images are installed (and upgraded) on my boards spi/nvme where I confirmed emmc working: http://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Orangepi5-plus_noble_vendor_6.1.84_kde-neon-kisak_desktop.img.xz http://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Orangepi5-plus_noble_vendor_6.1.99_kde-neon_desktop.img.xz 0 Quote
Robert Pace Posted yesterday at 01:52 PM Author Posted yesterday at 01:52 PM On 4/6/2025 at 11:49 PM, Werner said: http://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Orangepi5-plus_noble_vendor_6.1.84_kde-neon-kisak_desktop.img.xz http://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Orangepi5-plus_noble_vendor_6.1.99_kde-neon_desktop.img.xz Domain resolves, but ftp is not responding, hence links don't work. 0 Quote
Werner Posted yesterday at 03:11 PM Posted yesterday at 03:11 PM There is no ftp available. http/https only. 0 Quote
Robert Pace Posted yesterday at 05:55 PM Author Posted yesterday at 05:55 PM 2 hours ago, Werner said: There is no ftp available. http/https only. https link isn't functioning. I click and a new window opens and rapidly closes without automatic download. Using the latest Chrome (Version 135.0.7049.85 (Official Build) (64-bit)) within Windows 11 Pro, no pop-up blocker enabled. 0 Quote
eselarm Posted 16 hours ago Posted 16 hours ago 9 hours ago, Robert Pace said: https link isn't functioning works for me using wget in Linux terminal 0 Quote
Robert Pace Posted 16 hours ago Author Posted 16 hours ago 24 minutes ago, eselarm said: works for me using wget in Linux terminal wget in WSL works with the links for me. I think the issue the within chrome may have something to do with http (not https), when I change http in the link to https it works, or if I browse to the .testing folder. Odd. 0 Quote
