MrDindon Posted April 6, 2025 Posted April 6, 2025 I wanted to try anything other than the original image that the device came with. I was more interested in the Kali port but after trying for a few hours with pretty much all the images available here I had to revert to the original one. So I was wondering if anyone here ever tried these images or could give me some hint on what is wrong with it ? Basically just getting a red led with no display when trying all the images. I know the original image had a some sort of special boot process where the initial startup would take some time but I know nothing else about armbian at this point. My goal was to start doing some test with kali liking the formfactor of this device. Any help appreciated:) 0 Quote
Igor Posted April 7, 2025 Posted April 7, 2025 Can you provide more detailed info - last images were not tested as there were very little changes from previous one (check lastest from archive https://imola.armbian.com/archive/inovato-quadra/archive/)... Which images did you try and can you try daily images that are at the bottom of the page: https://www.armbian.com/inovato-quadra/ Also we are just about to merge big changes on Allwinner, so stay tuned. https://github.com/armbian/build/pull/8004 0 Quote
