Schuppeste Posted September 9, 2017 Posted September 9, 2017 Hi, i try to build my own UserPatch for orangepizero. Sometimes i use my own Workaround with Editing Build-Files (old Builder). Please explain me replacing "patch/kernel/sun8i-default/02-0011-fbtft_for_older.patch" with FB-TFT Original Sources. (More Devices) Thanks
Igor Posted September 9, 2017 Posted September 9, 2017 1 hour ago, Schuppeste said: Please explain me replacing "patch/kernel/sun8i-default/02-0011-fbtft_for_older.patch" with FB-TFT Original Sources. (More Devices) It might not be that simple. IIRC old kernel (<3.15) is supported to certain development point and from there on it's not supported anymore. Most likely unrelated to new devices, but to driver structure. Check with fb-tft docs / author: https://github.com/notro/fbtft
Schuppeste Posted September 9, 2017 Author Posted September 9, 2017 (edited) Okay, in my last kernel Workaround i have updated ili9486 Patch/kernel-source lines for 9481 but deleted my old files with new compile.sh update. Now i try make it easier through userpatch for next Build Tool changes. EDIT: i should use "diff git" now. FBTFT Sources was updated to Support "Device Tree Manager" in Kernel 3.5, "02-0011-fbtft_for_older.patch" patched to old Version 3.4 without Devm. (Without new Boards). Its easy to update new Devices by own need, only 1 Line just changed in Device Drivers Files. Edited September 9, 2017 by Schuppeste Solved
