serverlesslove Posted Wednesday at 08:19 AM Posted Wednesday at 08:19 AM (edited) Hi, I'm trying to setup CM3588Plus NAS 3 x 4tb vp4300 nvme drives OpenMediaVault updated. Drives are setup to RAID5 with ext4. the OS is reporting that ssd temps getting to 63-68C while idling, and likes to creep up to 75C where if I'm correct thermal throttling starts to kick in. the SBC is in open air, no case/enclosure. room temp 21C. How to find the cause and solve it? Amy recommendations setup (change the fs) etc. Thanks a mill. Edited Wednesday at 08:23 AM by serverlesslove updated details. 0 Quote
Werner Posted Wednesday at 10:34 AM Posted Wednesday at 10:34 AM Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Sirmalinton Posted Saturday at 04:00 PM Posted Saturday at 04:00 PM @serverlesslove, your mount options for the device might not be ideal. If the device is used as a multimedia server, then you can avoid, for example, updating file access times on each read, reducing disk writes and improving performance, using the `noatime` option. Also increase the file system journal commit interval to 120 seconds (instead of the default 5 seconds) using `commit=120`. Check your current `mount` options for the device and try these: ``` defaults,noatime,commit=120,errors=remount-ro ``` 0 Quote
Vijay Gill Posted Saturday at 08:07 PM Posted Saturday at 08:07 PM @Sirmalinton Are you sure this could be the reason? I have NVME's with btrfs running with following options in fstab defaults,noatime,nodiratime,compress=zstd,nodiscard,max_inline=0 And temperature is quite acceptable (see screenshot below). I had initially set up my NAS is the standard metallic case which was quite useless. So I got a 3d-printed one with a fan on the top to keep everything cool. See my post in another thread https://forum.armbian.com/topic/48705-cm3588-overlay-for-fan-speed-change/#findComment-214042. Now I don't have to worry about the temperatures at all. I must also mention that my NVME's have heatsink attached. 0 Quote
