mikeymike Posted September 11, 2017 Posted September 11, 2017 Hello, I'm trying to get an "Orange Pi Zero" running with Wifi and OV534 (Sony PS3 Webcam). I can't get both running at once. My attempts so far: Armbian_5.30_Orangepizero_Ubuntu_xenial_default_3.4.113: Wifi ok, no ov534 Armbian_5.30_Orangepizero_Ubuntu_xenial_dev_4.11.3: No Wifi, ov534 ok Armbian_5.32.170912_Orangepizero_Ubuntu_xenial_dev_4.11.12: No Wifi, ov534 ok I've read about XR819 on github posts (to use under 4.11), but I couldn't load it, there are three module files for this module: fw_xr819, boot_xr819 and sdd_xr819, but none of these is loading successfully: modprobe: FATAL: Module xr819 not found in directory /lib/modules/4.11.3-sun8i Is there a way to get both running together, Wifi and ov534? Thank you for your appreciated answer Michael
martinayotte Posted September 11, 2017 Posted September 11, 2017 The XR819 crappy driver isn't present in 4.11.x builds, simply because it is crappy and we don't want to officially support it. The only way to get it compiled, is to build your own image with the patches and defconfig enabling it.
raschid Posted September 11, 2017 Posted September 11, 2017 @mikeymikeTry this build ... IIRC it contains the wifi driver. https://dl.armbian.com/orangepizero/archive/Armbian_5.32_Orangepizero_Ubuntu_xenial_dev_4.11.7.7z Don't expect data rates substantially exceeding 10mbit/s.
mikeymike Posted September 11, 2017 Author Posted September 11, 2017 Thank you very much, @raschid ... that image is perfect, I can work with wlan0 and also with /dev/vide0!! However, an "apt dist-upgrade" destroyed the wlan0 after reboot. For being an octoprint controller only for the LAN, protected by a sophisticated firewall and only online when printing, I think that is a risk I can take (not to be upgradable). And the speed is also fine. And of course, I have to cool it properly, the one chip heats up to over 65°C while idling, that's a bit hot, but I've seen other threads discussing that. Heatsinks and fans are on the way to my house. I'm so glad, thank you again. Is it planned for the near future to support WLAN with that kernel? What's the latest? Time for some Orange Juice ... (is that what "Orangers" say to each other? ;-) ) Michael
mikeymike Posted September 11, 2017 Author Posted September 11, 2017 Other thought: If I wanted to use the other "stable" image, which webcam would work? (AliExpress preferred).
raschid Posted September 12, 2017 Posted September 12, 2017 @mikeymikeTo avoid loosing wlan0 with update/upgrade you have to freeze the kernel using the "freeze kernel" option in armbian-config. My OpiZ idles at about 35°C (in a case) with WLAN active. I assume you have version 1.4 board, right? Sorry, can't help you with the webcams.
mikeymike Posted September 12, 2017 Author Posted September 12, 2017 Ok, great, @raschid, thanks, you helped me a lot with the "freeze kernel" option, I've started with a pre-injected connection in /etc/NetworkManager/system-connections, then first login via wlan0 connection and then issued apt update and apt upgrade and it works very nice: a reboot comes up again with a working wlan0. And yes, it's a V1.4. I assume the 4 in 1.4 means that I have to use 4 fans in order to keep it in thermal shape.
raschid Posted September 12, 2017 Posted September 12, 2017 Very good. Yep, 4 fans sounds about right
