svv Posted April 19, 2025 Posted April 19, 2025 Hello! I’m using Armbian 25.2 image. It seems there is a bug in the device tree. I have enabled ethernet@5030000. But ethernet doesn’t work. Does anyone know where to find the tree with the correct description of the ethernet@5030000 node for use with internal phy? 0 Quote
Solution Werner Posted April 19, 2025 Solution Posted April 19, 2025 Maybe you find some clues here: https://github.com/armbian/build/pull/6617/files SoC is the same 1 Quote
svv Posted April 20, 2025 Author Posted April 20, 2025 23 часа назад, Werner сказал: Maybe you find some clues here: https://github.com/armbian/build/pull/6617/files SoC is the same Thank you very much. This helped. 0 Quote
