My RPi PC2 was flashed the armbian OS which was downloaded from the main page ARMBIAN about 3 months ago. Yesterday, I found some packages update are available with "apt update".  So I did the command "apt upgrade" .  But from then on, the board never be boot up.
From the console,   the U-Boot version has been upgraded to 2017-09-rc4 from the old version 2017.01-rc1-g5df570f-dirty.   I'd appreciate it if anyone could help with this or give me some suggestion.
U-Boot SPL 2017.09-rc4-armbian (Sep 11 2017 - 03:34:11)
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):aa75c8d
NOTICE:  BL3-1: Built : 03:34:04, Sep 11 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2017.09-rc4-armbian (Sep 11 2017 - 03:34:11 +0200) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: OrangePi PC 2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
eth0: ethernet@1c30000
38518 bytes read in 132 ms (284.2 KiB/s)
Unknown command 'bmp' - try 'help'
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3362 bytes read in 190 ms (16.6 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 159 ms (0 Bytes/s)
** File not found /boot/dtb/allwinner/allwinner/sun50i-h5-orangepi-pc2.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
4179 bytes read in 409 ms (9.8 KiB/s)
Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
## Executing script at 44000000
5681602 bytes read in 488 ms (11.1 MiB/s)
12285960 bytes read in 894 ms (13.1 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    5681538 Bytes = 5.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-01-b3-6f-d0-61
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-sunxi
Config file not found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
Abort
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
Abort
Download older version and not update. You are using development image which comes without end user support.
Hint - DTB file is not in right location:
Thank you.
I have figure it out from an topic about pine64.  I modified and recompiled the boot.cmd. Now everything is Okay.
Had similar problem with 5.32 to 5.41  upgrade on orange pi win.
File not found /boot/dtb/allwinner/allwinner/sun50i-a64-orangepi-win.dtb
Just made the relative symlink and it helped.
# ll /boot/dtb/allwinner/allwinner/sun50i-a64-orangepi-win.dtb
lrwxrwxrwx 1 root root 29 Feb 14 19:48 /boot/dtb/allwinner/allwinner/sun50i-a64-orangepi-win.dtb -> ../sun50i-a64-orangepiwin.dtb
First stable image for Orange Pi Win with a legacy kernel was released on 10th of January, v5.37
"Mainline coming soon". Not released to this day.
We don't care if development versions break. It is expected that they break ... and we fix them ... they break ... and we fix again. And after a while, when this is not happening that often, an image is released.
