JRD McLAREN Posted April 25 Posted April 25 (edited) So, I'm got this "old" TV BOX as a gift, and I'm try to do something with this ... Now I have booted image for Odroid C1 (after 2 or 3 days work) Req. HW mod: - two resistors / wires for working console are needed - pics later HW & SW info: TV Box Name: Sencor SMP 5000PRO CPU: amlogic meson8b (s805 ??) Armbian build file name: Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz DTB file used: meson8b-odroidc1.dtb Kernel Version:6.12.13 Distribution Installed: bookworm Working Ethernet (Yes/No):??? Max Ethernet Speed that works: 100 Does wifi work (Yes/No): ???? Does bluetooth work (Yes/No):NO ?? Does HDMI audio work (Yes/No): It is Androind TV box, 1GB RAM, NAND flash 8GB, 1x LAN, WiFi, 2x USB 2.0, HDMI, SDcard slot, IR, 2 color status led, audio jack, Android 4.4.x I can provide some rom files, from stock android, or whole nand. and (maybe) need some help with this .. (thats all for this midnight) Edited April 25 by JRD McLAREN 0 Quote
JRD McLAREN Posted April 26 Author Posted April 26 bootlog file - from stock adnroid boot printenv - stock uboot enviroment printenv boot.log 0 Quote
SteeMan Posted April 26 Posted April 26 If you look at the boot log, the android firmware is first looking for s905_autoscript on the SD card fat partition. So you should be able to create a boot script by that name to get the native emmc uboot to run and boot what you have on your SD card. (Your printenv shows the boot order is determined in start_autoscript, first mmc then USB then finally emmc). If this ancient uboot is capable of booting a modern Linux kernel you should be able to make this work with the proper boot commands in the s905_autoscript file. 0 Quote
JRD McLAREN Posted April 26 Author Posted April 26 Yes, I know ... I will try it, when I have "working" dtb .. Now I have extracted original dtb from boot partition... 0 Quote
JRD McLAREN Posted April 28 Author Posted April 28 some photos ... and dts file with working hdmi, lan and two usb ports, "RED" led --- TESTED meson8b-sencor.dts 0 Quote
JRD McLAREN Posted April 30 Author Posted April 30 (edited) Chips: Amlogic S805 SOC Hynix H5TQ4G63AFR-PBC - DDR3 RAM -2x IP101GR - 10/100Mbps transceiver MT29F64G08CBABA - NAND Flash Memory RTL8189ETV - Wifi module Edited April 30 by JRD McLAREN 0 Quote
JRD McLAREN Posted May 9 Author Posted May 9 Is there anybody, who can help me with wifi module ..? or.. any utility to test / check gpios or. help me with gpio mapping in dts ..?? when I use dtb for meson8m2-mxiii-plus.dtb "Tronsmart MXIII Plus" tv box, wifi works fine... but, when I can replicate it on "my" dts for sencor (meson8b-sencor.dts) I have no success (two attached files for compare) Thanks.... meson8m2-mxiii-plus.dts meson8b-sencor.dts 0 Quote
JRD McLAREN Posted May 9 Author Posted May 9 OK .. now i must "cleanup" all voltage regulators 0 Quote
JRD McLAREN Posted May 13 Author Posted May 13 SO, I have working dts / dtb file for this device now.😃 It has working: - TF card / SD card slot - 2x USB ports (1+1) - HDMI - WIFI card - LAN 100Mbit - IR port - LEDs (red and blue) - CPU 4x - RAM 1GB - Serial console TODO: Nand flash - it will be good to have 8GB internal flash available for system AUDIO&CompositeVIDEO - yes, have sound will be good too .. JTAG - maybe ?? RTC - maybe ?? .. but, I'm not sure, if all of them is possible .... for this SOC... It runs on Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz image kernel is 6.12.17-current-meson - not latest one - because newer version have not 8198es module / driver meson8b-smp5000pro.dtb meson8b-smp5000pro.dts 0 Quote
JRD McLAREN Posted May 13 Author Posted May 13 (edited) link from armbianmonitor - https://paste.next.armbian.com/kozaluhulo ..and ... can anybody / admin or moderator remove "my files" /old dts/ from posts above please .. ?? ..thanks... Edited May 13 by JRD McLAREN 0 Quote
SteeMan Posted May 13 Posted May 13 3 minutes ago, JRD McLAREN said: can anybody / admin or moderator remove "my files" /old dts/ from this post please .. ?? I don't understand what you are asking for. Can you be more specific? 0 Quote
JRD McLAREN Posted May 14 Author Posted May 14 Ok .. sorry ... It is all "WIP" dts files / attachments. They don't work correctly on the device. (my testing files, posted in this thread, when I'm stuck "somewhere" and asking for help) ..all files like meson8b-sencor.dts, meson8m2-mxiii-plus.dts ... etc. 0 Quote
