JRD McLAREN Posted Friday at 10:17 PM Posted Friday at 10:17 PM (edited) So, I'm got this "old" TV BOX as a gift, and I'm try to do something with this ... Now I have booted image for Odroid C1 (after 2 or 3 days work) Req. HW mod: - two resistors / wires for working console are needed - pics later HW & SW info: TV Box Name: Sencor SMP 5000PRO CPU: amlogic meson8b (s805 ??) Armbian build file name: Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz DTB file used: meson8b-odroidc1.dtb Kernel Version:6.12.13 Distribution Installed: bookworm Working Ethernet (Yes/No):??? Max Ethernet Speed that works: 100 Does wifi work (Yes/No): ???? Does bluetooth work (Yes/No):NO ?? Does HDMI audio work (Yes/No): It is Androind TV box, 1GB RAM, NAND flash 8GB, 1x LAN, WiFi, 2x USB 2.0, HDMI, SDcard slot, IR, 2 color status led, audio jack, Android 4.4.x I can provide some rom files, from stock android, or whole nand. and (maybe) need some help with this .. (thats all for this midnight) Edited Friday at 10:18 PM by JRD McLAREN 0 Quote
JRD McLAREN Posted Saturday at 11:08 AM Author Posted Saturday at 11:08 AM bootlog file - from stock adnroid boot printenv - stock uboot enviroment printenv boot.log 0 Quote
SteeMan Posted Saturday at 12:23 PM Posted Saturday at 12:23 PM If you look at the boot log, the android firmware is first looking for s905_autoscript on the SD card fat partition. So you should be able to create a boot script by that name to get the native emmc uboot to run and boot what you have on your SD card. (Your printenv shows the boot order is determined in start_autoscript, first mmc then USB then finally emmc). If this ancient uboot is capable of booting a modern Linux kernel you should be able to make this work with the proper boot commands in the s905_autoscript file. 0 Quote
JRD McLAREN Posted Saturday at 04:45 PM Author Posted Saturday at 04:45 PM Yes, I know ... I will try it, when I have "working" dtb .. Now I have extracted original dtb from boot partition... 0 Quote
JRD McLAREN Posted Monday at 06:22 PM Author Posted Monday at 06:22 PM some photos ... and dts file with working hdmi, lan and two usb ports, "RED" led --- TESTED meson8b-sencor.dts 0 Quote
JRD McLAREN Posted 10 hours ago Author Posted 10 hours ago (edited) Chips: Amlogic S805 SOC Hynix H5TQ4G63AFR-PBC - DDR3 RAM -2x IP101GR - 10/100Mbps transceiver MT29F64G08CBABA - NAND Flash Memory RTL8189ETV - Wifi module Edited 10 hours ago by JRD McLAREN 0 Quote
