Posted (edited)
So, I'm got this "old" TV BOX as a gift, and I'm try to do something with this ...
Now I have booted image for Odroid C1
(after 2 or 3 days work)
Req. HW mod:
- two resistors / wires for working console are needed - pics later
HW & SW info:
TV Box Name: Sencor SMP 5000PRO
CPU: amlogic meson8b (s805 ??)
Armbian build file name: Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz
DTB file used: meson8b-odroidc1.dtb
Kernel Version:6.12.13
Distribution Installed: bookworm
Working Ethernet (Yes/No):???
Max Ethernet Speed that works: 100
Does wifi work (Yes/No): ????
Does bluetooth work (Yes/No):NO ??
Does HDMI audio work (Yes/No):
It is Androind TV box, 1GB RAM, NAND flash 8GB, 1x LAN, WiFi, 2x USB 2.0, HDMI, SDcard slot, IR, 2 color status led, audio jack, Android 4.4.x
I can provide some rom files, from stock android, or whole nand.
and (maybe) need some help with this ..
(thats all for this midnight)
Edited by JRD McLAREN
If you look at the boot log, the android firmware is first looking for s905_autoscript on the SD card fat partition.  So you should be able to create a boot script by that name to get the native emmc uboot to run and boot what you have on your SD card.
(Your printenv shows the boot order is determined in start_autoscript, first mmc then USB then finally emmc).
If this ancient uboot is capable of booting a modern Linux kernel you should be able to make this work with the proper boot commands in the s905_autoscript file.
Posted (edited)
Chips:
Amlogic S805 SOC
Hynix H5TQ4G63AFR-PBC - DDR3 RAM -2x
IP101GR - 10/100Mbps transceiver
MT29F64G08CBABA - NAND Flash Memory
RTL8189ETV - Wifi module
Is there anybody, who can help me with wifi module ..?
or..
any utility to test / check gpios
or. help me with gpio mapping in dts ..??
when I use dtb for meson8m2-mxiii-plus.dtb "Tronsmart MXIII Plus" tv box, wifi works fine...
but, when I can replicate it on "my" dts for sencor (meson8b-sencor.dts) I have no success
(two attached files for compare)
Thanks....
meson8m2-mxiii-plus.dts meson8b-sencor.dts
