Jurgen.Schober Posted May 2 Posted May 2 I got a 6.1 noble minimal image installed with a latest kubuntu update to KDE 6. Was quite some work to get this all working. But some thing aren't working (e.g. audio?). 6.12 and later supports a range more peripherals. I tried the non-vendor images but no go. How do I install one of those? (Not using ROOBI, I hacked this to use my own) 0 Quote
prahal Posted May 16 Posted May 16 Mainline audio is not working. Vendor audio is working but not activated by default yet 0 Quote
Jurgen.Schober Posted June 2 Author Posted June 2 (edited) Replying to my own post. ... EDK2 has an UEFI BIOS which runs mainline linux - no custom builds. It supports ACPI and device tree. I run this now with Fedora Rawhide 43 with KDE (6.4 Beta) which runs ACPI out of the box, older kernels work with device tree. I haven't used the latest mainline Armbian but that should work, too (at least the latest mainline image). Rawhide runs mainline kernel 6.15/6.16 (latest build) which supports the SOC + GPU out of the box. Edited June 2 by Jurgen.Schober 0 Quote
