Raul
  1. Thanks. Jut thinking - Maybe it’s better that the topic is validated via a forum thread before opening PR rather than create junk PR clutter due to mistaken notions … ?
  2. Hey Folks I was reviewing apps and software I want installed on my new NAS and it seems like building an HA image (armbian build) will include desktop as well - whereas I only use a headless server. I thought everything runs on a WebUI these days - why then does Armbian default to Desktop build for HA?
  3. If you have a PC then easy to setup the armbian build environment and build kernel only, copy the deb files over and run dpkg . The minimum version covering all CVEs is now 5.18.60. I just built mine yesterday and dropped them in …
  4. Mass install in a factory assembly line is another thing. For the home users all you have to do is use boot from an sdcard image dd command with infile=imgfile.img and outfile=emmc device, then power-off, remove the sdcard and power-on... Thats how I installed mine to emmc.
  5. --delete-- I misread your goal ...
  6. Hello I built my custom server image with LUKS encryption and everything was fine with regards to the encrytped rootfs on emmc. However I ran into boot failure issues when I tried adding other disks with LUKS encryption (because I had moved /var to new LUKS disk). After some time spent in debugging and recovery it turned out that my custom built Armbian never ran systemd-cryptsetup-generator to dynamically generate the systemd units needed to unlock encrypted volumes during boot and hence failed to correctly setup and hit the corresponding cryptsetup.target Finally I ended up installing package systemd-cryptsetup manually and run systemd-cryptsetup-generator to resolve it (auto-generate the target unit files - update-initramfs after editing /etc/crypttab should trigger it, but in this case the package itself was missing?), and it cost me a few hours troubleshooting why... (more so because I was determined not to introduce a manual hack/override for something that should not be broken in the first place). I think by default Armbian build framework should include the systemd-cryptsetup package (for both server and minimal), when CRYPTROOT_ENABLE is set - as encryption is a basic default configuration these days.. Thanks PS: At this point I have forgotten the reasons I had deduced why cryptroot worked and only the additional LUKS disks were impacted. But in any case the ask/fix is small - the Armbian build environment should include package systemd-cryptsetup by default without having to resort to extensions or userpatches ...
  7. Hello I was trying to move from dhcp to static IP and tried it via armbian-config. No change happened.. The interface remains with its dhcp assigned IP. When I check : rock-5-itx:/etc:% sudo ls /etc/netplan 10-dhcp-all-interfaces.yaml armbian.yaml ls -l /run/systemd/network total 16 -rw-r----- 1 root systemd-network 123 Nov 3 15:58 10-netplan-all-eth-interfaces.network -rw-r----- 1 root systemd-network 125 Nov 3 15:58 10-netplan-all-lan-interfaces.network -rw-r----- 1 root systemd-network 125 Nov 3 15:58 10-netplan-all-wan-interfaces.network -rw-r----- 1 root systemd-network 207 Nov 3 15:58 10-netplan-enP3p49s0.networkIIRC netplan needs its config updates in a sorting order with the "last matching rule wins". Looks like this may be the reason - above you can see my intended static IP config file 10-netplan-enP3p49s0.network was generated for my custom settings (from armbian.yaml) with all other files also beginning with 10-netplan-* in /run/systemd/network. I am guessing that due to a lack of explicit sort ordering the config update probably stopped with the catch-all group definition configs 10-netplan-all-[eth|lan]* ... ?? Not sure (guessing here) whether using a naming convention like 90-netplan-* or similar in /etc/netplan will result in the proper application of the manual configuration change ...? PS: Changing armbian.yaml to 20-armbian.yaml and running netplan generate/apply did not fix. So it looks like the 10-netplan-all-* generic file is winning over the 10-netplan-enP3p49s0.network
  8. Ah My bad! I can confirm that the image boots successfully and the files are correctly populated in /boot and EFI: Thanks for fixing this! I am sure a lot of people are going to appreciate seeing the traditional Linux boot folder structure and layout - esp the folks with the ITX boards... Cheers and have a Great weekend ahead!
  9. Thanks for the effort! I ran and built the image. This works to create 3 partitions: (Yes I changed UEFI SIZE to 256 above hoping that kernel files would go into p2 /boot) ... However the change does not fix the kernel files appearing in EFI partition p1 rather than a p2 /boot partition. Let me know if you plan to fix this because the grub.sh code seems to have been designed and written around that assumption: I checked this in a hurry and not sure if simply changing the code to this will work: If you don't plan to fix that - then I am planning to boot with the /boot files in p1 then copy the kernel files over to p2 and then run an edit fstab and an update-grub sequence with os_prober to create a new grub entry and try booting from it before I delete the files in p1... Thanks!
  10. I created the new image - while the partitions were correctly created all the kernel files meant for /boot landed in the EFI partition. A lot of things need to be changed in the code like fstab and grub entries to correctly point to initrd and vmlinuz in /boot on p2 instead of the combined efi+boot ... too fatigued to do this now. Will just settle for the default architecture with everything in UEFI_MOUNT_POINT ... sigh!
  11. I was able to get it work by changing this around line#47 of extension/grub.sh and then setting the following params in the compile config: The build almost finished completely with: Then unfortunately I ran into a github token expiry situation: But I think I get the partition layout I wanted originally now - will need to wait for the token expiration thing to get over before I can dd it to my emmc and test. Need to verify if the kernel files correctly get populated in p2 mounted at /boot and EFI at /boot/efi ... @Igor Would you like to consider the change I tried - if it can be made a part of Armbian just like pr-11072 that you did?
  12. It works. (I ran a git checkout -f pr-11072 to force overwriting my earlier local changes first). I have some additional questions that I hope you can quickly answer? I really want a separate EXT4 /boot and the FAT32 EFI mounted under /boot/efi ... preferably encrypted /boot (I hear modern grub can read encrypted /boot - does armbian version grub do that?). I am kinda uncomfortable with my core kernel files on a FAT32 filesystem without any permission features. How do I make that happen with a custom build? The following set of parameters dont seem to do it (esp BOOTFS_TYPE=ext4) as you can see in the fdisk output of the image I just created. I was hoping this was the switch to do it - BOOTFS_TYPE=ext4 combined with BOOTPART_REQUIRED but it does nothing. Thanks
  13. Thank you for the prompt fix! However I was already tinkering in the meantime without checking for updates here and managed to create a 512M /boot by editing extensions/grub.sh directly and the resulting build gave me: Now its installed and running. But tell me the exact git command (I am not a dev) to pull your specific change and I will ensure I test it by creating a new image and report back tomorrow with the output of fdisk -l on the img file. PS: When I tried the lvm extension without the grub.sh hack it still created a 260M /boot and a single LV for rootfs (I was hoping there would be a EFI paritition, and a PV partition with boot and root LVs [giving ample space for new kernel upgrade/build]but that did not happen). EDIT: And I just read your comments and it makes sense - FAT32 cannot symlink hence the issue... In any case I just realized that since I built a custom kernel (with custom kernel parameters) I cannot apt upgrade it but need to do a kernel-only build on my amd64 host and copy it over... but anyways I hope my stupidity helped improve Armbian by just a bit ... Cheers and Thanks!
  14. UEFISIZE=512 did not do it. At this point I am now stuck... Every apt upgrade one does on a system from Armbian Build environment is going fail requiring manual intervention ... Unless I move to an LVM based build ... trying that now ...
  15. Hello, I noticed this during my previous build as well. I just built a new Armbian image for my rock-5-itx and booted it after installing to emmc. I used the following build commands However the built image has only a 256MB partition. The net result was that the very first apt upgrade failed to build and install the new kernel... The pristine image when booted first time has only 66MB free out of the 256MB while in the midst of the upgrade likely because apt upgrade is doing write of bak file before delete.. /boot after the failed upgrade (output is from 2nd manual run of update-initramfs): How can I get the BOOTSIZE=512 parameter to work with compile.sh? I reviewed the Armbian build documentation in its entirety before this build and nothing caught my eye about any potential gotchas that might cause this parameter to fail. Lastly I think a default of 256M is too miserly. Besides requesting the quick cmdline/config fix for the build, I hope the Armbian build developers will take note and bump the default to 512... EDIT: I forget the crucial but minor details - there is no boot partition when I build for UEFI. so the /boot and EFI is a combined 256GB FAT32. So either I set UEFISIZE to 512... Or how to force seperate EFI/Boot/RootFS? Looks like BOOTPART_REQUIRED=yes and BOOTSIZE=512 are only honored when LVM is selected for build? PS: Trying a build with UEFISIZE=512 now ... Thanks
