Guest Posted May 11, 2025 Posted May 11, 2025 I just tested the latest, 2025 May, built image with default/recommended options and there are some missing features. Here is what I have tested: LAN yes WiFi yes BT yes USB3 *partly, some devices are not detected at all, some will take a few minutes before detected* GPU Mali-G610 (Panfrost) HDMI audio *no* Fan control yes temp. sensor htop *no* Temp. sensor Gnome *no* Other: some cursor graphic glitches Armbian-unofficial_25.05.0-trunk_Rock-5c_noble_current_6.12.28_gnome_desktop.img Any ideas on how to get more features supported? 0 Quote
Solution Werner Posted May 12, 2025 Solution Posted May 12, 2025 14 hours ago, sakittelsen said: current Use edge or vendor for more features. current will stick to 6.12 LTS kernel which will receive fixes only. 0 Quote
Guest Posted May 12, 2025 Posted May 12, 2025 (edited) It loooks like the Panfrost gpu driver is made as a module in the kernel configuration, marked with an M and not *. If I want this module to be built into the kernel, can I change it from M to * to do this? When built as a module, how do I turn it on? Is it in armbian-config (under overlays) or some other place? Edited May 12, 2025 by sakittelsen 0 Quote
Werner Posted May 13, 2025 Posted May 13, 2025 9 hours ago, sakittelsen said: If I want this module to be built into the kernel, can I change it from M to * to do this? https://zuckerbude.org/armbian-using-kernel-config/ 9 hours ago, sakittelsen said: When built as a module, how do I turn it on? https://www.google.com/search?q=google+how+to+load+linux+kernel+modules 0 Quote
Guest Posted May 13, 2025 Posted May 13, 2025 3 hours ago, Werner said: When built as a module, how do I turn it on? Turning it on using armbian-config works and is easy (overlay). 0 Quote
Werner Posted May 13, 2025 Posted May 13, 2025 Loading a kernel module has nothing to do with enabling a device tree overlay. 0 Quote
Guest Posted May 13, 2025 Posted May 13, 2025 (edited) Worked for me Enabled the Panfrost gpu driver in overlay settings in armbian-config. Just a coincidence that it was already available as an overlay option. Edited May 13, 2025 by sakittelsen 0 Quote
