Guest Posted May 13, 2025 Posted May 13, 2025 In Gnome, there are two shortcuts, armbian-config and armbian-configNG. What's the difference? 0 Quote
Werner Posted May 13, 2025 Posted May 13, 2025 I assume the armbian-config shortcut is a left-over from the old version of this tool: https://github.com/armbian/config It has been replaced with https://github.com/armbian/configng 0 Quote
Guest Posted May 13, 2025 Posted May 13, 2025 So, i should use armbian-config in terminal and armbian-configNG in Gnome. 0 Quote
Werner Posted May 14, 2025 Posted May 14, 2025 I don't know where these shortcuts link to, but I assume they both link to the same executable script which is the next generation version. I am not aware that any current Armbian image still ships the old version. So at the bottom-line there is no difference. 0 Quote
