lay Posted May 14 Posted May 14 How to reset the armbian system and restore the initial configuration operation 0 Quote
IBV Posted May 14 Posted May 14 Hi, not sure if there's a way to do this, I would re-flash the SD card with the image you were using. That will re-trigger the initial config. 0 Quote
Werner Posted May 14 Posted May 14 Only possible with starting over with a fresh image written to sd. Armbian does not come with some sort of overlayfs. 0 Quote
lay Posted May 15 Author Posted May 15 I want to pre place the img image in the file system. How do I burn it to the system? 0 Quote
IBV Posted May 15 Posted May 15 Take a look here: https://docs.armbian.com/User-Guide_Getting-Started/#deploy-the-image 0 Quote
