Guest Posted May 14, 2025 Posted May 14, 2025 I'm using an external USB SSD to build an image, and get this error: Adding Armbian repository and authentication key [ image-early :: /etc/apt/sources.list.d/armbian.sources ] [🌱] Disabling Armbian repo [ arm64-bookworm :: skip:no when:image-early ] mount: /media/steven/SSD/build/.tmp/rootfs-988d6aec-74e2-4c44-bd6b-013049454c46/armbian/cache: special device /armbian/cache does not exist. dmesg(1) may have more information after failed mount system call. [💥] Error 32 occurred in main shell [ at /media/steven/SSD/build/lib/functions/general/chroot-helpers.sh:32 mount_chroot() --> lib/functions/general/chroot-helpers.sh:32 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:20 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
Werner Posted May 15, 2025 Posted May 15, 2025 3 hours ago, sakittelsen said: dmesg(1) may have more information after failed mount system call. Check this. Also full logs are missing. 0 Quote
Guest Posted May 15, 2025 Posted May 15, 2025 I can run sudo dmesg but I do not know how to get dmesg(1)? log-build-9961f8b1-1871-49b2-948e-792d2d09ac33.log 0 Quote
Guest Posted May 15, 2025 Posted May 15, 2025 (edited) To fix a mounting error, I run this before building: sudo mount -o remount,exec,dev /media/steven/SSD dmesg log: [ 27.549272] EXT4-fs (sda1): mounted filesystem 221b4559-9c69-4721-82eb-31346e1f1592 r/w with ordered data mode. Quota mode: none. [ 92.494161] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd [ 92.515767] usb 4-1: New USB device found, idVendor=8564, idProduct=1000, bcdDevice=11.00 [ 92.515773] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 92.515778] usb 4-1: Product: Mass Storage Device [ 92.515782] usb 4-1: Manufacturer: JetFlash [ 92.515785] usb 4-1: SerialNumber: 24092700000000000094 [ 92.639937] scsi host1: uas [ 93.006034] scsi 1:0:0:0: Direct-Access JetFlash Transcend 128GB 1100 PQ: 0 ANSI: 6 [ 93.028170] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 93.028508] sd 1:0:0:0: [sdb] 241637376 512-byte logical blocks: (124 GB/115 GiB) [ 93.029793] sd 1:0:0:0: [sdb] Write Protect is off [ 93.029799] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 93.032413] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 93.090555] sd 1:0:0:0: [sdb] Preferred minimum I/O size 512 bytes [ 93.090562] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes [ 93.125990] sdb: sdb1 [ 93.126108] sd 1:0:0:0: [sdb] Attached SCSI disk [ 93.293219] ntfs3: Enabled Linux POSIX ACLs support [ 93.293226] ntfs3: Read-only LZX/Xpress compression included [ 175.283172] EXT4-fs (sda1): re-mounted 221b4559-9c69-4721-82eb-31346e1f1592 r/w. Quota mode: none. Edited May 15, 2025 by sakittelsen spelling error 0 Quote
laibsch Posted May 15, 2025 Posted May 15, 2025 shot in the dark. maybe this is a regression due to a recent commit @sakittelsen Try "git revert 9eaa276457e11" and try again. 0 Quote
Guest Posted May 15, 2025 Posted May 15, 2025 Do I need a git account? I get these replies: steven@rpi5b:/media/steven/SSD/build$ git revert 9eaa276457e11 Author identity unknown *** Please tell me who you are. Run git config --global user.email "you@example.com" git config --global user.name "Your Name" to set your account's default identity. Omit --global to set the identity only in this repository. fatal: unable to auto-detect email address (got 'steven@rpi5b.(none)') steven@rpi5b:/media/steven/SSD/build$ sudo git revert 9eaa276457e11 error: your local changes would be overwritten by revert. hint: commit your changes or stash them to proceed. fatal: revert failed steven@rpi5b:/media/steven/SSD/build$ 0 Quote
Guest Posted May 15, 2025 Posted May 15, 2025 I should also say I run "./compile.sh KERNEL_BTF=no" because I have only 4 GB of RAM. 0 Quote
