akaix Posted May 15, 2025 Posted May 15, 2025 Hi, unable to install any sofware, error: docker: Error response from daemon: failed to set up container networking: network lsio not found 0 Quote
Solution akaix Posted May 16, 2025 Author Solution Posted May 16, 2025 Reinstall docker from armbian-config solved problem, with manual installed docker it won't work. 0 Quote
Igor Posted May 16, 2025 Posted May 16, 2025 42 minutes ago, akaix said: with manual installed docker it won't work. Network bridge is added within armbian-config Docker install ... Perhaps open a ticket https://github.com/armbian/configng so this is eventually done properly. 0 Quote
