lay Posted May 20, 2025 Posted May 20, 2025 Kind people: How to modify the default swap partition size in the configuration file and compile the firmware?? help help 0 Quote
Solution Werner Posted May 20, 2025 Solution Posted May 20, 2025 Try setting ZRAM_PERCENTAGE=50 where 50 would be half of available memory. Not sure if the builder picks this up. If it doesn't I'd go the customize-image.sh route and use this to modify the /etc/default/armbian-zram-config file just before assembly closure. 0 Quote
