Guest Posted May 26, 2025 Posted May 26, 2025 (edited) I know the edge kernel and trixie build is not supported, but it builds just fine, but during the first boot it fails when setting the root password. Any fix? Edited May 26, 2025 by sakittelsen 0 Quote
Werner Posted May 26, 2025 Posted May 26, 2025 1 hour ago, sakittelsen said: it fails elaborate 0 Quote
Guest Posted May 26, 2025 Posted May 26, 2025 (edited) I enter new root password once, and enter return. Then I type the new password again, but before I hit enter, the command promt jumps to loggin. Then I'm stuck. Edited May 26, 2025 by sakittelsen spelling error 0 Quote
Guest Posted May 27, 2025 Posted May 27, 2025 (edited) I guess the problem is that I'm using a simple 2 character password. It has been working fine until now. I'll try a long password next time. Update: Nope, still fails with a longer password. Edited May 28, 2025 by sakittelsen 0 Quote
bpi-user Posted September 27, 2025 Posted September 27, 2025 I had the same problem when trying this directly on my Banana PI M5. But when I connected from my notebook via ssh everything worked fine and I could create the root and user password. Afterwards login was also possible directly on the machine. 0 Quote
