I used the Armbian test image.
I did apt-get upgrade
I changed eth0 to static IP.
But now, I started it up and eth0 green light won't stay on. Can't ping it or SSH.
I connected a USB PL-2303HX from my PC to the NanoPi Neo2 (first time for me ever connecting to a Linux computer's serial console)
With no configuration at all I got this output in minicom.
U-Boot SPL 2017.09-armbian (Sep 17 2017 - 03:48:48)
DRAM: 4096 MiB
Trying to boot from MMC1
NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):aa75c8d
NOTICE:  BL3-1: Built : 02:45:22, Sep 17 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
Looks like U-Boot can't find the kernel or whatever?
Okay I removed the 5v wire from the USB serial adapter so I can rather power the board via microUSB 2A adapter than weak USB port power.
I unplugged and replugged the 2A microUSB but it didn't help.
With the microUSB unplugged the PCB's green LED still glowed faintly somehow powered from GND and tx/rx.
rneese suggested I unplug and replug everything.
I did and now it booted up and I can see it on the console. It's saying no ethernet found and it looks like a console so I'll give it a go.
U-Boot 2017.09-armbian (Sep 17 2017 - 03:48:48 +0200) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO 2
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
38518 bytes read in 134 ms (280.3 KiB/s)
Unknown command 'bmp' - try 'help'
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3362 bytes read in 179 ms (17.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 149 ms (0 Bytes/s)
** File not found /boot/dtb/allwinner/allwinner/sun50i-h5-nanopi-neo2.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
4179 bytes read in 362 ms (10.7 KiB/s)
Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
## Executing script at 44000000
5001834 bytes read in 452 ms (10.6 MiB/s)
12285960 bytes read in 868 ms (13.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    5001770 Bytes = 4.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
starting USB...
No controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
No ethernet found.
=> ls
ls - list files in a directory (default /)
Usage:
ls <interface> [<dev[:part]> [directory]]
    - List files in directory 'directory' of partition 'part' on
      device type 'interface' instance 'dev'.
=> su
Unknown command 'su' - try 'help'
=> help
?       - alias for 'help'
base    - print or set address offset
bdinfo  - print Board Info structure
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootefi - Boots an EFI payload from memory
bootelf - Boot from an ELF image in memory
booti   - boot arm64 Linux Image image from memory
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
bootvx  - Boot vxWorks from an ELF image
cmp     - memory compare
coninfo - print console devices and information
cp      - memory copy
crc32   - checksum calculation
dhcp    - boot image via network using DHCP/TFTP protocol
dm      - Driver model low level access
echo    - echo args to console
editenv - edit environment variable
env     - environment handling commands
exit    - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls  - list files in a directory (default /)
ext4size- determine a file's size
false   - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatsize - determine a file's size
fatwrite- write file into a dos filesystem
fdt     - flattened device tree utility commands
fstype  - Look up a filesystem type
go      - start application at address 'addr'
gpio    - query and control gpio pins
help    - print command description/usage
iminfo  - print header information for application image
imxtract- extract a part of a multi-image
itest   - return true/false on integer compare
lcdputs - print string on video framebuffer
load    - load binary file from a filesystem
loadb   - load binary file over serial line (kermit mode)
loads   - load S-Record file over serial line
loadx   - load binary file over serial line (xmodem mode)
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
md      - memory display
mdio    - MDIO utility commands
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mw      - memory write (fill)
nfs     - boot image via network using NFS protocol
nm      - memory modify (constant address)
part    - disk partition related commands
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
pxe     - commands to get and boot from pxe files
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
save    - save file to a filesystem
saveenv - save environment variables to persistent storage
setcurs - set cursor position within screen
setenv  - set environment variables
setexpr - set environment variable as the result of eval expression
showvar - print local hushshell variables
sleep   - delay execution for some time
source  - run script from memory
sysboot - command to get and boot from syslinux files
test    - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true    - do nothing, successfully
usb     - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
Boot process changed. Start with a new image and don't' update. I hope you understand that we don't care to provide any stability for testing images? They work or not.
Quote
The file is one path up. Copy it there.
Thanks Igor
I reflashed a fresh image and it's working now.
I was planning to test stability of the image using it as a home router.
I thought I can contribute by doing an upgrade and then seeing what breaks or how to keep it working after upgrade?
If you don't reply before I get this maybe I'll try upgrade again and then copy the file as you suggest.
BTW it's amazing having one of these USB PL-2303HX hooked up to the NanoPi Neo2 for testing. It just works instantly and perfectly on Ubuntu 16.04 with 4.10 kernel with zero configuration of baud settings, parity etc, and I expect it will work with other SBC's like the Orange Pi's and RbPi's ?
After re-flashing I saw the whole boot process all the way from U-Boot and then was offered a root console and could login and use the PC just like if I had attached a screen, kb and mouse, but so much more convenient of course because it's a terminal on my dev PC and I can probably paste into minicom.
At least this bug is known. Since we only produce testing images for those boards at the moment failed upgrading is not considered as a bug. Stable images are expected in 1-2 months. If you like to contribute, start with some simple problems. Anything that saves us time. If you are familiar with bash scripts, this needs extensive testing and some code cleanup.
Serial console is a must debug tool in our world.
Thanks Igor.
I have some familiarity with Bash scripts, however every time I have worked on a complicated bash script I've sworn to myself to never work on a complicated bash script ever again.
So I only use bash for very simple stuff.
For complex things I use php7-cli scripts
For very complex things I use node.js.
I'll check it out though.
I found an alternative to apt-get upgrade, to upgrade things without breaking the image.
`apt-get upgrade` N (then see what needs upgrading that's not firmware etc related)
`apt-get upgrade apt hostapd` (etc)
For basic system stuff and for compatibility reasons, we have no much alternatives than using bash scripts. They are just fine for the job. I also follow a similar pattern and since I currently don't need very complex scriptings :) php CLI is my top level.
Check apt-mark ... it's integrated into armbian-config https://github.com/armbian/config/blob/dev/debian-config-jobs#L477
This reply is just for anyone interested in using NanoPi Neo2 to do useful things (which ideally should be apt-get upgradable)
I completely respect that you don't support this and there's no need for armbian devs to spend time reading this, cos it's working.
Okay I upgraded everything except
armbian-firmware armbian-tools-xenial linux-dtb-dev-sun50iw2 linux-headers-dev-sun50iw2 linux-image-dev-sun50iw2  linux-u-boot-nanopineo2-dev linux-xenial-root-dev-nanopineo2 sunxi-tools
And then just for fun I ran the upgrade to try your fix.
The upgrade completed successfully. I rebooted.
It was fine but gave the error about missing dtb file.
I created the allwinner dir inside the allwinner dir, copied the file there. rebooted, nomore errors, except this CRC error
U-Boot 2017.09-armbian (Sep 22 2017 - 09:14:02 +0200) Allwinner Technology
DRAM:  512 MiB
In:    serial
Out:   serial
Err:   serial
but it boots and there's nothing more to upgrade.
The reason PHP-cli is not my top level is at times when I need to do asynchronous stuff or maybe need functionality not available in PHP. But that's more in the terrirory of software than scripts. I've also come to much prefer ES6 syntax over PHP. PHP is really badly designed language. Not as bad as bash, but still very bad. It is however very useful, simple and convenient.
This is normal.
Regarding Neo2. I recommend building an image from sources - I can add one testing image later.
