Andro Posted September 24, 2017 Posted September 24, 2017 No matter what I do, when I use an Armbian image built with compile.sh I get a blank orange screen on the OPi Plus 2. The downloadable pre-built image from Armbian for the board works fine. Wanting to debug this, I have an Adafruit UART serial cable adapter, known functioning and working. If I attach this to the UART pins on the small header near the power socket I get no output (and I have swapped RX and TX to no avail). How does one enable this UART? Am I using a wrong approach? I have console=both in armbianEnv.txt.
Igor Posted September 24, 2017 Posted September 24, 2017 UART is enabled by default. Which image are you trying to build?
Andro Posted September 25, 2017 Author Posted September 25, 2017 Builduing any Armbian image, headless or desktop, for any of the Orange Pi series results in a blank orange screen on boot and no futher action. The UART outputs nothing. However, the downloadable prebuilt Armbian image does work. As to the UART problem, I am beginning to suspect a board hardware problem. As to the non-booting issue, I have no idea. I did observe that I could find the IP address and ssh into the machine despite this lack of display output. Are there logs I could find to help diagnose this issue?
Igor Posted September 25, 2017 Posted September 25, 2017 On 9/25/2017 at 2:11 AM, Andro said: As to the UART problem, I am beginning to suspect a board hardware problem. As to the non-booting issue, I have no idea. Expand Board configurations, u-boot configs can be sometimes broken upstream for a single board. This can lead to boot failure - has to be investigated.
