A cheap UAC 1.0 in to UAC 2.0 out converter that allows your PS5, switch, etc to use high end speakers
Posted (edited)
Hi, I would like to share my recent work: a cheap USB Audio Class 1.0 (UAC) input to UAC 2.0 output converter.
For folks that may not understand why I have this crazy idea, here is the background:
For some shitty reasons, PS5 does not support outputting audio through certain USB sound card, and that is because PS5 only supports very old USB sound card (UAC 1.0), and usually high end speakers or sound cards would use newer, better UAC 2.0 protocol.
So, this shitty thing happens to me, when I thought my EDIFIER S880 speaker would be a plus for my gaming experience. EDIFIER S880 has a UAC 2.0 in input source, so my PS5 does not support that. So, what I can do is to use another 3.5 jack to connect the speaker to my PS5.
Unfortunately, there is a staticky buzz sound throughout this channel. What's even worse is that EDIFIER S880 has 6 input source selection, but I can only switch to the next source, wait for 2 seconds, and repeat this process 5 times every time I want to switch the audio from my computer to the PS5.
After lots of trials and flashing my custom kernel, I finally did it!
The idea is to use a board that has 1 USB otg port to act as a UAC 1.0 sound card, and has another 1 USB host port to connect to the UAC 2.0 speakers, then run programs on that board to redirect sound from USB otg port to USB host port. It is even a plus that the board consumes less power, so we do not need an extra or special power supply for it; this becomes crucial, especially when sharing the same USB connection with the USB otg port (SBC boards are more power-hungry these days!). The standard USB 2.0 protocol only allows 5V 0.5A to the device connected.
I actually built one with an Orange Pi One board, but it turns out that the CPU is not fast enough, and there are sound glitches sometimes.
With some research, I found this board that perfectly fits my needs: Radxa zero 3W. Here is the advantage:
- It is cheap, and the one I used is the nearly minimum SKU (1 GB ram with 8 GB onboard eMMC, they also have no onboard eMMC SKU).
- The otg port could handle USB PD protocol, meaning no special hacks are needed, you could get at most 30W of power, if needed (and turns out the normal USB 2.0 port on my PS5 works perfectly, so I guess it consumes less than 5V 1A = 5W)
- It is tiny.
However, things don't work right out of the box. At the beginning, I flashed the official, latest Radxa OS, modprobe the g_audio. It is running as a UAC 2.0 device, so it is not the one I want. As a result, I grabbed their kernel source, changed the config to UAC 1.0 gadget, and flashed onto the board, but there seems to be some issues in their kernel fork for UAC 1.0 driver: there was no /dev/snd/controlC0, so the g_audio failed to run.
As a result, I turned to use the Armbian build. This time, the /dev/snd/pcmC0D0c is missing, so g_audio failed to run again.
I then compiled my own kernel, flashed it onto the board. The Armbian build is with kernel 6.1, and the kernel I built is kernel 6.12, then the board failed to boot to the kernel due to U-Boot thought there were some errors.
Luckily, I found that building the whole Armbian image with kernel 6.12 can boot without issues, so I built a custom kernel 6.12 with UAC 1.0 enabled image, modeprobe the g_audio module, and it finally worked!
After that, I crafted a simple golang SystemV daemon for bootstrapping and terminating the alsaloop program for redirecting the sound, and used a udev rule to notify that daemon of the attachment/detachment of the USB speaker out event. The converter is finally working!
Here is the pre-built image for folks who want a quick test. It is based on the commit b27c86e620dcd9f55daadf52ccc85643dba2a381 from the armbian build repo with the following config modification:
diff --git a/config/kernel/linux-rockchip64-current.config b/config/kernel/linux-rockchip64-current.config
index d053d0997..6e360bba7 100644
--- a/config/kernel/linux-rockchip64-current.config
+++ b/config/kernel/linux-rockchip64-current.config
@@ -3507,3 +3507,8 @@ CONFIG_RATIONAL_KUNIT_TEST=m
 CONFIG_MEMCPY_KUNIT_TEST=m
 CONFIG_TEST_MEMCAT_P=m
 CONFIG_MEMTEST=y
+CONFIG_USB_CONFIGFS_F_UAC1=y
+CONFIG_USB_CONFIGFS_F_UAC2=n
+CONFIG_USB_F_UAC2=n
+CONFIG_GADGET_UAC1=y
Currently, the "current" build does not detect the Wi-Fi interface, but as it does not affect the audio converting feature, I may not put too much effort into this.
Edited by 李松錡
HI I arrived here after buying a Hiby R3II and trying to use it on my PS5. Stupid Gemini sayed that it has a software toggle to UAC 1 but it doesn´t. So I´m seeing what to do and this option popped up. Do you think it may work with the PS5 front USB? I looked for the board and is around 35 USD in Aliexpress shipped to Europe. Is that regular price? thanks a lot.
Posted (edited)
Yes, absolutely works with the front USB.
I do not know the regular price, that depends on the spec you choose (how much RAM, is eMMC included). I got the similar price for that board including shipping, but do note that it was shipped from China to Taiwan.
Hmm, that's true for Hiby R3II, checking from the manual, it actually says:
Quote
When the player works on USB audio, you can think of the player as a USB HD decoding receiver or as a USB sound card. The player works on USB audio supports the USB Audio Class 2.0 (UAC2) protocol, but does not support USB Audio Class 1.0 (UAC1), so the host side also needs to support USB Audio Class 2.0 (UAC2).
Edited by 李松錡
Hi, I learnt how to customize the image, and also found a simpler way to achieve the bootstrapping alsaloop. Here is the forked repository and a pre-built image for you to try. Supposedly, you just need to flash the image, and it should work out of the box. As the radxa zero 3w does not have the Ethernet port, so you will not accenditally connect it to some networking, I think it is fine to leave the root password as the default.
However, if you plan to connect the device to some networking, remember to set up the root password. The Wifi is also working with the latest kernel release (my wifi module is broken, but I do see dmesg is trying to interact with that module).
Posted (edited)
Thanks a lot, I´m thinking about buying a board purely for your image, would you advise me to wait for the nanopi r3s release? I have an old rpi 3  collecting dust, do you think I may use that as well?
thanks
Edited by Taladro
