Orange Pi 5 Plus multiple "fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing HDMI pull out, return!" errors on boot
Go to solution Solved by Werner,
After enabling the rk3588-hdmirx overlay in armbian-config device tree overlays, whenever I boot, I am greeted with multiple hdmirx (fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing HDMI pull out, return!) errors on boot.
On a previous install, the hdmirx errors would block the entire boot process and it would just hang forever. I do not know the exact cause, but the issues seemed to arise after I ran this command to disable the X Display Server "systemctl set-default multi-user.target".
The errors could only be resolved if I plugged in the sd card into another device and removed rk3588-hdmirx from overlays in /boot/armbianEnv.txt .
I have since reinstalled Armbian, but the errors still appear during the boot process, however now they do not block the boot process and I am able to successfully boot into Armbian.
Is there any solution to get rid of these errors, or ensure that the  "fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing HDMI pull out, return!" error doesn't block the boot process without disabling hdmirx?
These are my current device details:
               ..                     orangepi@orangepi5-plus
            `:]x**j-,'                 -----------------------
       .,+t***********z\<"             OS: Armbian 25.5.1 noble aarch64
       ?******************;            Host: Orange Pi 5 Plus
      '*n` .'`^,;;,^`'. ,cc.           Kernel: Linux 6.1.115-vendor-rk35xx
      -<.                .[l           Uptime: 30 mins
     //     ^^      ^^    \\           Packages: 1822 (dpkg)
     !^         ^^         ":          Shell: bash 5.2.21
    'tt}`     !~]rj_     ")t/.         Display: 3840x2160 @ 60 Hz
    Itttt?'   ~~]rr]   `{tttt,         DE: KDE Plasma 6.3.90
    \tttttt!""I_]r("""~tttttt1         WM: KWin (Wayland)
  '_tttttttttttt)ftttttttttttti.       WM Theme: Breeze
 \*ztttttttttttttttttttttttttf**[      Theme: Breeze (Dark) [Qt], Yaru [GTK3]
l**c)tttttttttttttttttttttttt(z**,     Icons: breeze-dark [Qt], Yaru [GTK3]
.z*x.`tttttttttttttttttttttttt.`u*n    Font: Noto Sans (10pt) [Qt]
>`   (tttttttttttttttttttttt]   "I     Cursor: breeze (24px)
     ,tttttttttttttttttttttt`          Terminal: konsole 25.4.1
     ./tttttfttttttttfttttt(           CPU: rk3588 (8) @ 2.40 GHz
      'I)))(\()(tt))|\()({;'           GPU: Mesa Mali-G610 (Panfrost)
        .~~~~~~~|)~~~~~~~<             Memory: 4.34 GiB / 15.58 GiB (28%)
        '[)))))1|()))))))?             Swap: 0 B / 7.79 GiB (0%)
          ",,,"    ",,,^               Disk (/): 7.82 GiB /
Here is the dmesg log after boot up, the hdmirx errors appear near the end:
boot_errors.txt
Correct way to provide logs:
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
