Stuck in login loop during first boot
Go to solution Solved by laibsch,
Using Jun 26's Sid_vendor_server-kali, my Zero 3W is stuck in a loop.
  1. I can't "Create a loop password" as it'll instantly jump to the "armbian-security login:" prompt.
  2. If I login with the default root:1234, I'll briefly see the welcome screen, followed by a very brief "waiting for the system to finish booting", then it's back to 1.
This occurs regardless of internet access (provided by a USB-C ethernet adapter, for which Armbian reports a valid LAN IP address).
How long did you wait for this? if you for example use a quite large microsd card that however has a slow pace this may take a few minutes.
Probably worth a shot - I had an install one time that gave me fits at initial boot.  For giggles I expanded the FS using Gparted in linux to fill the entire card.  It solved that problem for me.
  • Solution
Are you twwn on github, @tast ky?  As mentioned in the bug tracker, you need to try a different image.
Please keep the discussion of run-time issues in the forum.  This is where run-time bug triage happens.  Until the time one can essentially make a PR with a clear code fix, the forum is where we discuss run-time problems.
