tast ky Posted 23 hours ago Posted 23 hours ago Using Jun 26's Sid_vendor_server-kali, my Zero 3W is stuck in a loop. I can't "Create a loop password" as it'll instantly jump to the "armbian-security login:" prompt. If I login with the default root:1234, I'll briefly see the welcome screen, followed by a very brief "waiting for the system to finish booting", then it's back to 1. This occurs regardless of internet access (provided by a USB-C ethernet adapter, for which Armbian reports a valid LAN IP address). 0 Quote
Werner Posted 16 hours ago Posted 16 hours ago 7 hours ago, tast ky said: waiting for the system to finish booting" How long did you wait for this? if you for example use a quite large microsd card that however has a slow pace this may take a few minutes. 0 Quote
Tomas Catone Posted 3 hours ago Posted 3 hours ago Probably worth a shot - I had an install one time that gave me fits at initial boot. For giggles I expanded the FS using Gparted in linux to fill the entire card. It solved that problem for me. 0 Quote
