Hi all!
On NanoPi Duo2 I'm trying to use the builtin video hw processor.
ffmpeg already works with -hwaccel v4l2request but throws errors:
Press [q] to stop, [?] for help
[h264 @ 0x11645f0] Using V4L2 media driver cedrus (6.12.35) for S264
[V4L2RequestContext @ 0xae5f0db0] Failed to create buffer of type 1: Cannot allocate memory (12)
[h264 @ 0x11645f0] Failed setup for format drm_prime: hwaccel initialisation returned error.
dmesg
[ 8906.864389] cma: __cma_alloc: reserved: alloc failed, req-size: 3038 pages, ret: -12
[ 8906.872255] cma: number of available pages: 42@86+128@384+34@3550+34@6622+34@9694+34@12766+34@15838+34@18910+34@21982+1570@25054=> 1978 free of 26624 total pages
[ 8906.886783] cedrus 1c0e000.video-codec: dma alloc of size 12443648 failed
root@nanopiduo2:~#
I already did play around with armbianEnv tweaking extraargs cma  but no success.
I found a link talking about VPU device tree dma limitations https://git.sec.in.tum.de/croemheld/linux/-/blob/v5.1-rc5/Documentation/devicetree/bindings/media/cedrus.txt
Zitat
Device-tree bindings for the VPU found in Allwinner SoCs, referred to as the Video Engine (VE) in Allwinner literature. The VPU can only access the first 256 MiB of DRAM, that are DMA-mapped starting from the DRAM base. This requires specific memory allocation and handling.
I already decompiled the DT and verified there are is no such "reserved-memory"  section.   Is this the root cause?
Maybe someone can provide some hints or ideas confirming that I'm on the right track? If yes I'd give it a try adjusting the DT.
     T.
Posted (edited)
3 часа назад, schunckt сказал:
v5.1-rc5
v6.12.35
Please use the current documentation for the CURRENT kernel.
sun4i-a10-video-engine.yaml
sun8i-h3-deinterlace.yaml
Documentation/arch/arm/sunxi.rst
arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-duo2.dts
arch/arm/boot/dts/allwinner/sun8i-h3.dtsi
P.S.
Please read this.
repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner
Edited by going
Add P.S.
Great, thanks for the links!
Meanwhile it works partially. The DT tweaking was not needed. I made a mistake by specifying the armbian extraargs. I added a second line to armbianEnv.txt but realized all args must be one line. I had to increase cma=256M (Yes, really, tested all lower values). Then it works, BUT ...
Fun fact, will further investigate:
Decoding with "-hwaccel drm" results in lower fps (about 6..8) whereas software decoder goes up to 10 😀
Decoding has been verified with htop. CPU only => 4 cores 100%. hwaccel one core about 20% which is likely th e yuv to rgb and scaling.
Maybe this is still an issue caused by DT, at least when reading https://gregdavill.com/posts/allwinner-s3-videoencoders/
It specifies
memory-region = <&cma_pool>;
  which is missing in my decompiled DT, also the referenced reserved-memory section.
Maybe that's not needed if it's coded inside the driver or specified elswhere.
  T.
On 8/10/2025 at 7:34 AM, going said:
v6.12.35
If it doesn't work, compile your own Armbian with EDGE linux (what worked for me).
Stay away from Trixie at this time (its mpv doesn't work as well as Bookworm's)
4 минуты назад, robertoj сказал:
Which OS works well for you?
Some fixes are kernel specific. If I understand correctly, the "memory-region" is only necessary when using the legacy cedar driver with a more recent kernel. It is supported up to kernel 6.1. You can confirm CMA allocation by running "sudo dmesg | grep CMA" or by running "cat /proc/meminfo | grep Cma"
That's interesting, although cedrus only acts as the video decoding engine while the display engine is responsible for the actual rendering.
