q2210377 Posted October 16, 2017 Share Posted October 16, 2017 I tried to create my own image using the build script for Orange Pi Zero. But starting this crashes immediately. Any suggestions? U-Boot 2017.09-1 (Oct 13 2017 - 11:04:53 +0200) CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3382 bytes read in 125 ms (26.4 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 105 bytes read in 112 ms (0 Bytes/s) 6756432 bytes read in 594 ms (10.8 MiB/s) Found mainline kernel configuration 31232 bytes read in 532 ms (56.6 KiB/s) 780 bytes read in 996 ms (0 Bytes/s) Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo 506 bytes read in 751 ms (0 Bytes/s) Applying kernel provided DT overlay sun8i-h3-uart3.dtbo 4179 bytes read in 557 ms (6.8 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 reserving fdt memory region: addr=43000000 size=6d000 Loading Device Tree to 49f90000, end 49ffffff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 4.033284] Internal error: Oops - undefined instruction: 0 [#1] SMP THUMB2 [ 4.040328] Modules linked in: [ 4.043436] CPU: 2 PID: 1 Comm: init Not tainted 4.13.7-sunxi #1 [ 4.049216] Hardware name: Allwinner sun8i Family [ 4.053961] task: db0f6c00 task.stack: db0f8000 [ 4.058551] PC is at ret_fast_syscall+0x2/0x4c [ 4.063045] LR is at SyS_brk+0x115/0x13c [ 4.067002] pc : [<c0106602>] lr : [<c01fdae5>] psr: 60000013 [ 4.073309] sp : db0f9fa8 ip : 50c5387d fp : 00001000 [ 4.078571] r10: 00000000 r9 : db0f8000 r8 : c01067c4 [ 4.083836] r7 : 0000002d r6 : b6f45cf8 r5 : 00451034 r4 : 0000000a [ 4.090406] r3 : 00040d07 r2 : 00040d07 r1 : 00000000 r0 : 01f2c000 [ 4.096978] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [ 4.104158] Control: 50c5387d Table: 5a37006a DAC: 00000051 [ 4.109942] Process init (pid: 1, stack limit = 0xdb0f8210) [ 4.115553] Stack: (0xdb0f9fa8 to 0xdb0fa000) [ 4.119961] 9fa0: 0000000a 00451034 00000000 00000063 00001 [ 4.128204] 9fc0: 0000000a 00451034 b6f45cf8 0000002d 00000001 00000001 00000 [ 4.136446] 9fe0: 0046ff68 be9e1dac b6f5bbb0 b6f5cfa8 60000010 00000000 00000 [ 4.144702] Code: bfcc2807 20012000 0000bd08 b6720000 (1000f8d9) [ 4.150843] ---[ end trace b5fe179284fe5f90 ]--- [ 4.156218] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0b [ 4.156218] [ 4.165444] CPU0: stopping [ 4.168202] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.13.7-11 [ 4.175674] Hardware name: Allwinner sun8i Family [ 4.180494] [<c010d5b5>] (unwind_backtrace) from [<c010a02d>] (show_stack+0x) [ 4.188375] [<c010a02d>] (show_stack) from [<c082d9dd>] (dump_stack+0x69/0x7) [ 4.195732] [<c082d9dd>] (dump_stack) from [<c010c695>] (handle_IPI+0x261/0x) [ 4.203257] [<c010c695>] (handle_IPI) from [<c01013e7>] (gic_handle_irq+0x67) [ 4.210952] [<c01013e7>] (gic_handle_irq) from [<c010a9a5>] (__irq_svc+0x65/) [ 4.218540] Exception stack(0xc0d01f38 to 0xc0d01f80) [ 4.223665] 1f20: 00000 [ 4.231968] 1f40: 00000000 c0116001 ffffe000 c0d03fcc c0d03f6c c0ca13b8 c0dd0 [ 4.240272] 1f60: 00000000 dffffac0 01400000 c0d01f88 c010708b c010708c 4000f [ 4.248581] [<c010a9a5>] (__irq_svc) from [<c010708c>] (arch_cpu_idle+0x28/0) [ 4.256115] [<c010708c>] (arch_cpu_idle) from [<c014c43d>] (do_idle+0x115/0x) [ 4.263646] [<c014c43d>] (do_idle) from [<c014c689>] (cpu_startup_entry+0x19) [ 4.271354] [<c014c689>] (cpu_startup_entry) from [<c0c00ab9>] (start_kernel) [ 4.279644] CPU3: stopping [ 4.282435] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.13.7-11 [ 4.289933] Hardware name: Allwinner sun8i Family [ 4.294737] [<c010d5b5>] (unwind_backtrace) from [<c010a02d>] (show_stack+0x) [ 4.302610] [<c010a02d>] (show_stack) from [<c082d9dd>] (dump_stack+0x69/0x7) [ 4.309962] [<c082d9dd>] (dump_stack) from [<c010c695>] (handle_IPI+0x261/0x) [ 4.317484] [<c010c695>] (handle_IPI) from [<c01013e7>] (gic_handle_irq+0x67) [ 4.325178] [<c01013e7>] (gic_handle_irq) from [<c010a9a5>] (__irq_svc+0x65/) [ 4.332766] Exception stack(0xdb121f78 to 0xdb121fc0) [ 4.337889] 1f60: 00000 [ 4.346193] 1f80: 00000000 c0116001 ffffe000 c0d03fcc c0d03f6c c0ca13b8 c0dd0 [ 4.354496] 1fa0: 00000000 00000000 01400000 db121fc8 c010708b c010708c 4000f [ 4.362804] [<c010a9a5>] (__irq_svc) from [<c010708c>] (arch_cpu_idle+0x28/0) [ 4.370334] [<c010708c>] (arch_cpu_idle) from [<c014c43d>] (do_idle+0x115/0x) [ 4.377862] [<c014c43d>] (do_idle) from [<c014c689>] (cpu_startup_entry+0x19) [ 4.385558] [<c014c689>] (cpu_startup_entry) from [<40101491>] (0x40101491) [ 4.392595] CPU1: stopping [ 4.395386] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.13.7-11 [ 4.402883] Hardware name: Allwinner sun8i Family [ 4.407687] [<c010d5b5>] (unwind_backtrace) from [<c010a02d>] (show_stack+0x) [ 4.415562] [<c010a02d>] (show_stack) from [<c082d9dd>] (dump_stack+0x69/0x7) [ 4.422914] [<c082d9dd>] (dump_stack) from [<c010c695>] (handle_IPI+0x261/0x) [ 4.430436] [<c010c695>] (handle_IPI) from [<c01013e7>] (gic_handle_irq+0x67) [ 4.438130] [<c01013e7>] (gic_handle_irq) from [<c010a9a5>] (__irq_svc+0x65/) [ 4.445718] Exception stack(0xdb11df78 to 0xdb11dfc0) [ 4.450842] df60: 00000 [ 4.459145] df80: 00000000 c0116001 ffffe000 c0d03fcc c0d03f6c c0ca13b8 c0dd0 [ 4.467448] dfa0: 00000000 00000000 01400000 db11dfc8 c010708b c010708c 4000f [ 4.475756] [<c010a9a5>] (__irq_svc) from [<c010708c>] (arch_cpu_idle+0x28/0) [ 4.483285] [<c010708c>] (arch_cpu_idle) from [<c014c43d>] (do_idle+0x115/0x) [ 4.490814] [<c014c43d>] (do_idle) from [<c014c689>] (cpu_startup_entry+0x19) [ 4.498508] [<c014c689>] (cpu_startup_entry) from [<40101491>] (0x40101491) [ 4.505568] Rebooting in 10 seconds.. Link to comment Share on other sites More sharing options...
chwe Posted October 17, 2017 Share Posted October 17, 2017 When you compile your own armbian, it might be helpful to know what you changed compared to a standard armbian.. I'm not an expert there.. but providing as much information as possible makes it easier for others to get an idea whats wrong on your build. Link to comment Share on other sites More sharing options...
Andrea Bondavalli Posted June 7, 2018 Share Posted June 7, 2018 Hi, the problem seems to be related to kernel compiled with the THUMB2 instructions set enabled. In you kernel defconfig check if you have the following option enabled. CONFIG_THUMB2_KERNEL=y and disable it in case. This worked for me. BTW: the problem for me started when compiling the kernel using Yocto "rocko" release and it was not present in previous Yocto "pyro" release. Link to comment Share on other sites More sharing options...
